LS1 418 F1A Build Thread
Old Mar 25, 2010 | 01:53 PM
  #61
buzz12586's Avatar
Cool. I normally try to go every week as well.
Old Mar 27, 2010 | 10:07 AM
  #62
helicoil's Avatar
Originally Posted by 01Z28Camaro
Alright let me know, I'm dropping 10k plus doing this new set up. I'd be shocked if I ran the same times as before. Your set up should be good for mid 9s all day I'd think.
I would agree.
Old Apr 20, 2010 | 10:21 PM
  #63
laughatrice's Avatar
Got it back together last week couple changes ported LS2 intake (for strength) and replaced valve seats ended up with a slightly lower compression. Still need to work out the tune for the changes but it's getting closer.
Old May 6, 2010 | 10:44 PM
  #64
THE-HOWARD's Avatar
wow man the car looks great since the last time i saw it when dsm4u2nv had it
Old May 7, 2010 | 02:40 AM
  #65
Fb0dy0nly's Avatar
Originally Posted by helicoil
Is it my eyes, or does the casting in the bellhousing area on that block read
"5.7L". Isn't this a 418?
Its a Katech resleeved 346 to make a 418cid bore.
____
Since you swapped to the TH400, can you still manually change gears 1,2,3 with it?
What auto trannys can you do this with if setup that way? (sorrry for hijack)
Thanks
Car looks amazing, love the orange and new rubber, get some vids for us!
So you swapped intake mani's for compression? how does intake change compression or did I read your post wrong?
Any noticeable changes with ported stocker?
Old May 7, 2010 | 08:53 AM
  #66
Originally Posted by Fb0dy0nly
ISince you swapped to the TH400, can you still manually change gears 1,2,3 with it?
Thanks
Yea its a manual valve body so you have to shift it manually there's no "drive". I think any auto with manual valve body you have to shift manually. I know it's common with a powerglide and TH350.
I worded that bad I swapped intakes because I cracked the FAST 90 under boost. The lower compression is because I had material removed from the chambers when I got the valve seats fixed and I went to a thicker head gasket.
I hear a ported ls2 = 12hp over a non-ported ls2 n/a. I have no idea what it will do to my power I changed so much stuff it will be impossible to tell.
