Kentucky Turbo is doing TT my build
#45
I should be able to give you a ball park on the power pretty soon as my twin 67 billet build is just about done - 6 speed as well. As most people have pointed out now, you are going to need upgraded everything.
And to the person asking for pictures of turbos on both sides (also check out Speed Inc.'s builds -- lots of large twin turbo pics)
#48
I'm sure Tiago will give you more info but let me tell you this HIS car is freakin sick
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
made over 900rwhp with 13psi and 1000rwhp with 15psi If I'm not mistaken
IMO your Turbos are small for CI If you want sick power and no lag go with twin 70mm I think you can get full boost 3000rpm and can have 1000+rwhp with 16-18psi
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Good luck.
#49
I started a thread about Tiago's TT car over a year ago after seeing it at a local car meet. It has a poor cellphone pic of the engine bay.
https://ls1tech.com/forums/forced-in...turbo-lsx.html
#51
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#52
I am sure josh will chime in on the this set up.I will leave everything up to him.If he decides to go with turbonetic 70's then I am game.I had a cam speced out for this build using smaller turbos(gt35).it is a reverse split.
#53
The Tnetic 70's or 72's would be pure insanity as far as spool and power is concerned.
#54
At first i was going to use the APS extreme kit but as u know the aps deal.So the cam was speced out using smaller turbos. I guess that is why it is a reverse split due to somthing about the exhaust or something.sorry i know nothing about turbos. Do you think the 70's will effect the cam if it is design for a smaller turbo.like a 60-61mm if that.
#56
#58
While 67mm turbo's will come in off idle and be super aggresive I would like to see some 70 ro 72mm units on the setup. Shouldnt slow the spool up down but it would extend the upper power potential of the setup. Best thing of all is that the setup will fit all the way up to 78mm turbo's. Power will not be an issue. Taction,
, that's another story.
