oil feed and drain lines on a ls1
Old Aug 23, 2009 | 08:53 PM
ls1z28camaro's Avatar
Default oil feed and drain lines on a ls1
Where would you tap into your oil pan for your oil return on a turbo kit and where would you get your oil feed from for the turbo to get the oil ifanyone has pic that would help thanks.....
Old Aug 23, 2009 | 09:30 PM
GrahamHill's Avatar
Look up or down a couple threads for the silverado05's build thread. In one pic it has a pic of the feed line fitted above the oil filter and the return going back into the pan.
Old Aug 23, 2009 | 09:31 PM
GrahamHill's Avatar
here lol
Old Aug 23, 2009 | 09:43 PM
awesome thanks man thats exactly what i needed!!!!!!!!!!!!!!!
Old Aug 24, 2009 | 07:37 AM
JAX04's Avatar
i thought there were two ports, one was unfiltered oil, and one was filtered, in that general area?
Old Aug 24, 2009 | 10:23 AM
vipvegas's Avatar
does any body know what size fitting that push to lock is? -10an?
And what is the fitting used to go into the pan legnth and dimensions, or can somebody direct me I need to order one today.
Old Sep 17, 2009 | 12:38 PM
XtremeDime's Avatar
Where did you pick up that oil feed flange? Any install instructions?
Old Sep 17, 2009 | 05:28 PM
Tally TransAm's Avatar
oil feed flange above the filter is already there, just have to remove it to drill and tap it
i put my -10 pushlock return in the timing cover
Old Sep 17, 2009 | 06:05 PM
XtremeDime's Avatar
You dont need to buy anything aside from that blue fitting??
Old Jan 11, 2013 | 09:21 PM
JoshuaGrooms83's Avatar
Originally Posted by GrahamHill
here lol
thanks for the pic, was wondering where to place my return. alot of people talk about the timing cover and on the passenger side, but i wanted it on the same side. thanks a ton
quick question,
to tap a 1/2" NPT a 45/64 drill bit is a good size right? just making sure.
Old Jan 11, 2013 | 10:19 PM
i gues i kinda answerd my own question so ill help by posting up a round about answer for drill bit sizes for 1/2" NPT bit sizes. I found a pretty detailed chart conversion.
IN decimal
11/16 = 0.6875
45/64 = 0.7031
23/32 = 0.7188
so id assume any of these inside that range will be exceptable.
Also for future reference for 1/8npt for those of us that like NUMBERS on our drill bits, I resently tapped my turbo compressor for an 1/8 NPT. i used a 11/32 drill bit to accomplish this. worked out PERFERCTLY.
heres a complete list of NPT and drillbit size chart i found. hope it it helps
To Tap This Size Pipe:--------Use This Drill Bit:-----------Closest Fractional--------- Decimal Inches:
1/8-27 NPT------------------Ltr.R or 11/32------------- 11/32 ----- ------------- .3390
1/4-18 NPT ---------------- 7/16" -- ----------------- 7/16" ---------------- .4375
3/8-18 NPT------------------ 37/64" -------------------- 37/64" ------------------- .5781
1/2-14 NPT ----------------- 45/64" --------------------- 45/64" ------------------- .7031
Overkill but add it anyway
3/4-14 NPT --------------------- 59/64"-------------------59/64" -------------------.9219
1-11 1/2 NPT-------------------- 1 5/32"------------------1 5/32"-------------------1.1562
1 1/4-11 1/2 NPT-----------------1 1/2"--------------------1 1/2"-------------------1.5000
1 1/2-11 1/2 NPT -----------------1 47/64"-----------------1 47/64" ----------------1.7344
2-11 1/2 NPT --------------------2 7/32"-------------------2 7/32"------------------2.2188
(Recommended tap drill to use for 75% depth of thread)
Old Mar 13, 2013 | 08:07 PM
what alot of you arnt sharing that tap the return on the vehicle is HOW IN THE F!@# DO YOU DO THAT!?!!?! im going out tomorrow to buy either a right angle drill or a adapter so i can do this. I have to get a step drill bit so i can get inside that cramped area and i still cant get in there. THERES NO ROOM! lol ill see how it goes tomorrow.
Old Mar 13, 2013 | 08:51 PM
evo462's Avatar
I pulled the oil pan while I had the engine out and had the -10 AN fitting welded on.
Old Mar 13, 2013 | 08:53 PM
JAX04's Avatar
This, or use the timing cover or go to the valve cover...
Old Mar 14, 2013 | 01:01 AM
5.slow99's Avatar
wouldn't something like this work as well???
http://paceperformance.com/i-1080527...apter-kit.html
Old Mar 14, 2013 | 01:49 AM
fstr n u's Avatar
Mine is on the passenger side. Where it's located, the oil return line runs through the engine mount on the k-member perfectly.
Old Mar 14, 2013 | 06:58 AM
71 chevy's Avatar
quick release.... nice
is that a hydraulic quick release? .
whats the free flow rate of the part?
Old Mar 19, 2013 | 08:59 PM
fstr n u's Avatar
It is a hydraulic quick release. I'm not sure what the flow rate is. It is the fitting removed from the STS oil filler cap tapped into my oil pan with extra saudering to ensure stability in the oil pan. You'd have to confirm with an STS guy who knows more than I do what size the fitting is. I spent a bit of time trying to find the exact spot this would work in, and there is only a margin of a few millimeters front or back to work with without bending oil lines.
Old Mar 19, 2013 | 09:03 PM
71 chevy's Avatar
thanks for the information
Old Mar 22, 2013 | 11:45 AM
StangTamer's Avatar
Do you guys think this would work for the return so you wouldn't have to tap the pan? Just cap the out port for the cooler and use the turbo out for feed and the oil in for the return?
