370+ GT4276 Truck Manifold build
Old 08-30-2009, 07:39 PM
MUSTANGBRKR02's Avatar
Damn looks good. I need to come to your shop sometime and look at your car up close. I have only seen it flying by at some ridiculous speeds.
Old 08-30-2009, 08:37 PM
LS1RedZ's Avatar
Damn that looks good. I wana do a truck manifold setup on my car after seeing so many done.
Old 09-02-2009, 09:17 AM
382ssz28's Avatar
Looks good Juicy!! Nate should be very happy. I'm hoping to get a ride when I get back to TC.
Old 09-02-2009, 09:25 AM
veee8's Avatar
You may want to be the one driving, or you will need to bring some undies with you, you know how Nasty Nate drives!
Old 09-02-2009, 10:21 AM
Tzion_ben_Arthur's Avatar
very nice and clean!
Old 09-02-2009, 06:54 PM
nnracing's Avatar
Ya it will be one hell of a ride I can't wait to drop the hammer!!!!!
Old 09-02-2009, 08:30 PM
Sideways240sx's Avatar
Looks Good. Almost the same as my car except im th400, and leaning toward a 383 ls1 for boost vs the 370 iron block.
Good luck on the single digit pass next year.
Chris
Old 09-02-2009, 08:36 PM
nnracing's Avatar
Im hoping to click one off this year at lsx but will see whats the best youve run with yours?
Old 09-04-2009, 10:09 AM
382ssz28's Avatar
Damn, that's cold!!
Old 09-04-2009, 10:36 AM
veee8's Avatar
Wiring the car tomorrow, I may even have a startup video.
Old 09-06-2009, 10:13 PM
veee8's Avatar
Got the car running today. It has a fuel pressure issue from the regulator. I am going to pull the regulator off my car and try it.
I was able to crank the injector pulsewidth up enough to get it idling, but gauge wasn't working and regulator is non functional. I think it is just dumping it all back to the tank. Probably play with it on tuesday.
No leaks, and got the cooling system filled and bled.
Once I get the fuel system figured out, build the rest of the exhaust and throw the dash and gauges in it should be ready for a road test and alignment.
Old 09-07-2009, 09:29 AM
  #32
Stock motor on 6psi with the t56 it was a hi 11 second car with problems, and a maf tune.
Now the car is 400 lbs lighter, th400, going to get a built motor this winter, 2 bar sd(i got a stupid 98 ecu) so 14.7 psi i think easy low 10's, but a high 9 would be awesome.
Chris
Old 09-07-2009, 09:49 AM
  #33
Restricted User
98Z28CobraKiller's Avatar
Will the flexi sections hold up to the heat and pressure of a turbo hot side? I had no idea that was an option.
Old 09-07-2009, 10:09 AM
  #34
veee8's Avatar
Yes they are heavy duty stainless flex joints, it is something learned over the long haul. Lots of heat cycles causes the pipes to take a set, these ensure everything will line back up when reinstalled. They are a good idea. You just need to make sure the turbo is properly braced.
Old 09-07-2009, 10:18 AM
  #35
98Camarod's Avatar
Are those necessary with solid mounts?
Old 09-07-2009, 10:42 AM
  #36
veee8's Avatar
Not a bad idea, the pipes will take a set from heat cycles, and sometimes can be a bitch to go back together. The turbo is braced to the block, so the rocking of the motor mounts doesn't affect it in that regard.
Old 09-07-2009, 08:31 PM
  #37
lt1badbird's Avatar
are they the flex sections with the solid lining inside?
Old 09-07-2009, 09:15 PM
  #38
veee8's Avatar
Yeah they are fairly stiff. Just a slight "give"
Old 09-07-2009, 09:45 PM
  #39
lt1badbird's Avatar
the reason i ask is the non turbo specific flex sections w/o the solid liings like to pretty much implode on themselves and clog everything up
good ones
bad ones
Old 09-07-2009, 09:59 PM
  #40
veee8's Avatar
That could get ugly!
Quick Reply: 370+ GT4276 Truck Manifold build
