Wastegate reference ?
Old Sep 9, 2009 | 08:04 AM
kwiksilverz's Avatar
Originally Posted by 98Z28CobraKiller
The only issue that I see is when you go from 100% throttle to 0% throttle at the end of a pass. The sudden switch from boost to vacuum would slam the valve shut which causes the BOV to work harder at relieving the charge pressure. At the very least it will make that obnoxious srt4 blow off sound.
Boost will drop to 0psi very quickly once the throttle is lifted regardless. It is really a non-issue. The sound of the BOV all depends on the type of valve and the amount of boost being run in the first place. I have yet to notice an audible difference due to boost source for the waste gate- and I have installed more boost controllers than many here have seen . Heck, technically, I have owned over 10,000 MBC's over the years .
