L92 or LS2 Boost ???
Old Sep 6, 2009 | 09:40 PM
GONEB4U's Avatar
Default L92 or LS2 Boost ???
I am looking to change up my combo in my 69 Camaro over this winter. I have a complete LS2 and a L92. What I'm looking to do is run a blow through Carb setup with a T76 turbo with a front mount intercooler. I will be using truck manifolds for this build. The KEY to this build is keeping the expense to the minimum. Whatever motor I end up using will have a turbo cam, matching springs ( and lifters if L92), ARP head bolts and ARP main studs as a mod. I am looking to keep everything else about the motor stock. I was thinking that 15psi should be attainable with the stock heads. I am not looking to spin the motor past 6200 rpm.
I would like to know which motor would you use ( and why) and whats the Max safe boost that it should be able to handle? Can I reuse the stock rods? Will they handle the power that a T76 @15psi can put out? Do you think that I need ARP rod bolts? Should I put aftermarket rods and pistons in it?
Old Sep 8, 2009 | 10:11 PM
GONEB4U's Avatar
Old Sep 8, 2009 | 10:19 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Definitely go ARP rod bolts. I "think" L92 heads flow more than LS2, so I would go with whichever flows better. As for rods and pistons, those just don't fit into a "budget" build. As far as max safe boost, my computer would blow up if I even tried to answer that loaded question. BTW, the rod bolts are much more important than main studs. Just think, 2 rod bolts vs 6 main studs, with each carrying about the same load.
Old Sep 8, 2009 | 10:28 PM
LQ9CHEVELLE's Avatar
Your stock pistons are more than likely going to break before anything. Hate to say it 'cause i know ill sound like a jerk, but do a search! Lots of info on stock motors + boost. Alot of people do it, most wind up exploding at some point, some much sooner than later. 550 RWHP seems to be the limit most agree on...anything past that your pretty much on borrowed time, gotta have a very safe tuneup and some luck. Of course some guys pull it off and are still rolling, but id venture to say that that statisticly isn't the norm. GOOD LUCK!
Old Sep 8, 2009 | 10:54 PM
SS2win's Avatar
If you want budget then you need to go with a stock 5.3, arp rod bolts, Z06 cam and upgraded springs.
Old Sep 9, 2009 | 12:19 AM
firstta25's Avatar
i would go with the l92
Old Sep 9, 2009 | 07:05 PM
GONEB4U's Avatar
Thanks for adding nothing to my post. If I wanted budget then I would drive one of your cars.
Old Sep 9, 2009 | 07:12 PM
Shawn @ VA Speed's Avatar
my suggestion is to put in rods and pistons-it will be worth it in the long run.
Old Sep 9, 2009 | 07:37 PM
SS2win's Avatar
Well when you said "expense to the minimum" I figured you'd do better with a 5.3. Boost the L92 and tell us how you do fawker!
Old Sep 9, 2009 | 07:39 PM
sr71's Avatar
^^^ good advice. all you need to do is grenade a stock piston and put a chunk of it through the turbo. that would really wreck the budget.
if you keep your eyes open, there are good deals to be had on pistons and rods in the classifieds. except for the block, I've bought everything for my new engine at killer deals from the for sale section. I even bought a new set of custom lingenfelter spec je pistons for $350. on my budget, the classifieds are my main source of parts.
Old Sep 9, 2009 | 07:49 PM
GONEB4U's Avatar
I agree. I will put in a set of Diamond pistons with a set of Eagle or Compustar rods. I think I will stay with my 6.0 iron block for a block foundation. I agree that the 4 sale section on tech is killer. Alot of great deals can be found. I since uped the turbo to a PT88. Now which head should I use, L92 or LS2? I'm thinking that none of these heads are going to live long behind the PT88 @15psi. What do you guys think?
Old Sep 9, 2009 | 08:00 PM
sr71's Avatar
if you stay conservative on the tune, the ls2's should be fine. I had a set of patriot "ls6 style" heads on my 402 with twin 76's. they were living just fine at 15psi. I have no experience with l92's though. so I will not comment on them.
if you are going to reuse the block from the car in you sig, I would reuse the heads too.
Old Sep 10, 2009 | 02:26 PM
98Z28CobraKiller's Avatar
Restricted User
My LQ9 stock long block lived to about 16-17 psi and then put a rod out of the side. I haven't ripped into it yet but I am pretty sure that first I broke a ring land and then I stretched or broke a rod bolt.
Old Sep 10, 2009 | 02:39 PM
GONEB4U's Avatar
I've been tempted to just put in a stock LS2 that I have out of a Trailblazer SS and give it a try but I don't want any of the parts of a gauranteed meltdown to go through my nice new turbo and turn it to .
