1BAD_LS1.....Budget 5.3 Truck manifold Turbo
Old 09-15-2009, 10:21 PM
  #41
blazin's Avatar
Wiring them backwards might work but the pitch of the fan blade is what matters. If I wired my flex a lites backwords they would move air but not enough new blades and problem solved.
Old 09-16-2009, 09:42 PM
  #42
Restricted User
1BAD_LS1's Avatar
ya i was kinda worried about that.... if they dont work good enought ill just break down and buy some pusher fans from summit.
Old 09-16-2009, 09:55 PM
  #43
Restricted User
1BAD_LS1's Avatar
RIMS AND TIRES CAM IN TODAY!!!!
My pitbull wanted to be in the picture.... I think he was jelous about all the attention the rims and tires were getting lol!
These should really help traction issues!!! and give it that badass drag car look!
Old 09-16-2009, 10:54 PM
  #44
dudeman's Avatar
ya, when i pulled my stock fans out i wired them backwards and they moved very little air. i couldnt see them moving enough air to keep it cool. your probably going to need some good pushers.
Old 09-16-2009, 11:31 PM
  #45
TX RED's Avatar
Is there a way to flip the blades ....
Old 09-16-2009, 11:32 PM
  #46
Restricted User
1BAD_LS1's Avatar
ok got curious and it was gonna bug me all night and i wasnt gonna be able to sleep so.... i went and grabed a fan and wired it up to cordless drill battery 18v lol. pulls awesome flip it around very little air...
I trimmed up the fan blade and tried everything and it just wont work without the blade being reversed also. and thats not really possible.... so im gonna have to buy a pusher fan.
What is the best BUDGET pusher fan????
Old 09-23-2009, 10:41 PM
  #47
Restricted User
1BAD_LS1's Avatar
Havent made a whole lot of progress lately been really busy at work... hope to get it done and ready to fire up this weekend!
Left to do:
Cold pipe
Down pipe (gonna drive it to the shop at work to do the downpipe lol)
Radiator hose's
Some wiring
TUNE IT
Old 09-23-2009, 10:47 PM
  #48
therobman's Avatar
nice build you also have to change ur plate to 1BAD 5.3
Old 09-23-2009, 10:52 PM
  #49
Restricted User
1BAD_LS1's Avatar
thanks.... ya i thought about that! My username also! LMAO....
I think ill just leave them for now.... i have other things to spend the money on besided new custom plates, depending on how the motor holds up and what it puts down i might change it eventually.
Old 09-24-2009, 05:09 PM
  #50
01SOMZ28's Avatar
when you get this done you should really bring this bitch to Lincoln so i can see it up close and maybe take a ride....hopefully i won't be addicted to boost afterwards!
Old 09-25-2009, 11:48 PM
  #51
Restricted User
1BAD_LS1's Avatar
well i got the cold pipe mocked up tonight... thats about it (no pics though, it was dark)..
I am hoping i can get it 98% done this weekend so i can start tuning on it... things always seem to come up! lol
Old 09-26-2009, 08:03 AM
  #52
Floyd946's Avatar
nice build
Old 09-26-2009, 10:51 AM
  #53
Reject's Avatar
drive way warrior, fkk yeah!
i did all my **** in my drive way too. good progress btw
Old 09-27-2009, 05:14 PM
  #54
Restricted User
1BAD_LS1's Avatar
Hell ya so im not the only one!
Old 09-27-2009, 05:27 PM
  #55
Restricted User
1BAD_LS1's Avatar
Got all the cold pipe done, mounted the trans cooler, got the dual catch cans setup, oil lines for turbo ran, radiator and fans mounted, all wiring done, boost guage installed, ect... ITS ALIVE AGAIN!
all i have left is to bleed the brake lines, 2nd walbro, 3 point SFC's, lca brackets, Downpipe, and tuning....
AND 1 problem to figure out! ---> I reversed the wires for the fans to run them backwards well they wont turn on! The car got way past the 160* turn on temp! I checked the DTC's with the scanner and it comes up with fan relay failure! WTF, reversing the wires shouldn't cause them to not work. i dont think...
I will get pictures up later!
Old 09-27-2009, 05:59 PM
  #56
Reject's Avatar
MightyMouse
https://ls1tech.com/forums/tools-fab...ml#post5790207
Reject
https://ls1tech.com/forums/6511747-post179.html
your not alone
Old 09-27-2009, 09:40 PM
  #57
Restricted User
1BAD_LS1's Avatar
didn't get pictures taken... got the fan problem figured out though.
After checking everything over and deciding to take it for an EASY (no boost) to the gas station well i get a block away to a stop sight and look in the mirrorand had a small trail for about 15ft!!!!!!! it was oil!!! the damn timing cover seal is leaking!!
So I have to tear the damn thing down again! This really pissed me off tonight! I just wanna sell it now, lmao....
I will get pictures sometime im just so pissed that i can look at it right now!
Old 09-27-2009, 09:52 PM
  #58
Black_98Z's Avatar
what was up with your fans?
Old 09-27-2009, 11:29 PM
  #59
zacht's Avatar
digging the build man!!!! keep up the good work...
just sucks cuz im going to have to do something big just to keep up with you.....
Old 09-28-2009, 12:51 AM
  #60
Restricted User
1BAD_LS1's Avatar
a wire grounding out
Quick Reply: 1BAD_LS1.....Budget 5.3 Truck manifold Turbo
