Time for my Front mount!
I mounted the can behind the bumper to where the bumper support use to mount, is there any negative side effects of mounting here, too low or anything?
2nd what do you do with the PCV line? Right now I just have it plugged at the intake and the 2 valve covers running to the catch can. What should I do to keep some kind of pcv or is it needed?
We were not able to hook the boost controller up as the car was just making too much power on the spring .. 7.6 psi on the spring with 16.5 degrees of timing on 93 octane the car put down a very impressive 547HP 507ft/lb of torque corrected!
Now the guy that tuned it has never tuned with HP tuners before so there are a few idle issues and things I have to work out but the driviability is perfect and AFR through the curve doesn't get above 11.7
Great build! Man that video does stink, do you have the better one? Quick question though. In your sig it says 472/468 but on the thread it says you dynoed 547/507..?
