View Poll Results: Power Poll (Sig Motor) 10psi, 93oct.
460-470
7.69%
470-480
0
0%
480-490
0
0%
490-500
15.38%
500-510
7.69%
510-520
7.69%
530-540
23.08%
540-550
7.69%
550-560
7.69%
560-OMG Blown Motor!
23.08%
Voters: 13. You may not vote on this poll
Time for my Front mount!
Old 09-07-2009, 10:49 PM
Super Slow SS's Avatar
Smile Time for my Front mount!
So I took advantage of the long weekend to get some wrench time in on my camaro, I have a long thread on here for the custom rear mount setup which I abandoned in lue of a front mount setup...
For this round of mods I got an old (but never used) Phamspeed turbo kit reusing my intercooler and scavange pump from my old kit, adding 317's with springs new pushrods and a z06 cam, some 65lb/hr precision injectors and a 2 bar map to go SD. So below are the pics of the progress over the weekend..
Old 09-07-2009, 10:54 PM
[Thanks Mods]
this is the original Phamspeed kit, not the one that is being faked on E-Bay right now, although I might have had better luck with that one, everything seems to fit okay but I am going to have to take the car to a fab shop the pass. side v-band flange does not line up with the header its the right length and all, just the wrong angle so i'll have it cut an re-welded.
other than that everything has gone mostly unhitched, wont get a chance to work on the car again till next weekend, hope to clearance the radiator a bit more and mount the return oil pump, plum the lines and get the new thin puller fans mounted, I will also need an alt. relocation bracket, if anyone has one send me a PM or if you know where I can get a good one or make my own I need help with that.
Old 09-08-2009, 12:04 AM
99Z28LS1's Avatar
looks good
Old 09-08-2009, 08:00 AM
So while im in here might as well put the questions up too.
I have a guy that is going to fix the v-band flange angle for me and weld some other things, for my old setup I used 2.5" intercooler piping even thought the turbo and the intercooler itself have 3" openings, my question is, should I redo everything in 3" piping, is it worth the money to replace everything when I have it already in 2.5"?
Old 09-08-2009, 08:12 AM
99Z28LS1's Avatar
I would do 3" piping, although I can't prove that it would be a restricion if you went from 3" to 2.5". My intercooler goes from turbo 2.5" for about 8" then it steps to 3"
Old 09-08-2009, 08:30 AM
Did you do the piping yourself or did you pay a shop to fab it?
Old 09-08-2009, 08:33 AM
99Z28LS1's Avatar
Kentucky turbo kit, non A/C
Old 09-08-2009, 10:36 AM
RS_SS69's Avatar
Looks good, at least step it up to 3" from intercooler outlet to t-body. Look at this thread for making your own alt bracket. https://ls1tech.com/forums/forced-in...old-build.html
Old 09-08-2009, 10:57 AM
Reject's Avatar
where did you get those oil lines at?
Old 09-08-2009, 11:46 AM
That is a line I had for the return when it was rear mounted I just kind of looped it around so no foreign stuff could get into the turbo, I have a SS line for the feed that i got from nitro daves and the return line I got from inline fluid power, they are a local shop that does a lot of high temp high pressure fittings and hoses.
Old 09-08-2009, 11:47 AM
Thanks for the link!!
Old 09-08-2009, 02:06 PM
Does anyone have pics of how their pipes come from the ends of the intercooler through the black plastic boxes where the horn and overflow tank are one the passenger side and where the air pump is on the drivers side? (I am no longer using the air junk, and will be removing that pump.
Old 09-08-2009, 02:22 PM
RS_SS69's Avatar
Im assuming that the pipes are being routed through them by just cutting a notch out of the plastic to clear them, thats the only way I can see it happening.
Old 09-08-2009, 02:37 PM
But i just dont know how people are moving the stuff that those boxes cover, it seems like a 3" pipe wont fit without moving some things in there.
Old 09-08-2009, 03:01 PM
RS_SS69's Avatar
You have alot of room without the air pump, as for the passenger side make a bracket for the horns to move if they are in the way.
Old 09-08-2009, 05:28 PM
Tally TransAm's Avatar
you have to move the horns on the pass side. just drill a couple new holes in the frame to remount them.
looks good though man, keep it up
Old 09-08-2009, 09:47 PM
Just got off the phone with my fab guy, he is coming over to look the parts over tomorrow and hopefully start welding some of the odds and ends for me, have someone else working on a alt. bracket tomorrow and Thursday.
If I can get my tune modified so it will start it just might be able to crank it this weekend.
Old 09-14-2009, 03:51 PM
Coming back up, got some progress this weekend and some pics, will be up later tonight.
Got the kit fixed to match up to the headers downpipe made, wastegate flange changed, clearanced the radiator support and now rewiring the stock fan (just one) to be a pusher.
Old 09-14-2009, 07:14 PM
98Camarod's Avatar
It looks good so far
Old 09-14-2009, 08:33 PM
Well here are the pics as promised, but i think I have ran into a problem, I think I got the wrong map sensor, it is pictured. Looking up the number it came off of a cobalt but I think it is a 1 bar .. and I dread changing it if it is.
Quick Reply: Time for my Front mount!
