forged piston broke... what happened
heres a couple pics... it was blowing smoke and started stumbling at idle... felt a little down on power and had only 40 psi of compression so i decided to pull the motor and this is what i found
stock rods are fine, only running 10 psi and made about 600hp/tq
![](http://i9.photobucket.com/albums/a83/extremetoy/piston.jpg)
![](http://i9.photobucket.com/albums/a83/extremetoy/piston2.jpg)
yea just the second ring is broke in a couple places... i cant remember what i gapped them to, it was whatever my machinist told me to... i have it written down ill look around
I can't see the pictures b/c I'm at work....but reading what is said I'd guess either you ran that particular cylinder rich and some fuel got under the rings, or the rings were gapped too tight.
-Will
-Will
were they breaking because of too little ring gap like someone else said or is it just those pistons, or a tune... btw why have all that custom work done instead of just going with a different piston alltogether.
