reverse flow stock fans?
Old Sep 21, 2009 | 07:26 PM
importkiller_SS's Avatar
Default reverse flow stock fans?
I didnt know where to post this question, but since i am doing something related to FI i thought i would post in here.
Can you switch the polarity of your stock fans and put them as pusher setup?
Old Sep 21, 2009 | 07:55 PM
Dean95z28's Avatar
I did one of mine and it works fine! I cut my fans in half and used one as a pusher the other as a puller.
Old Sep 22, 2009 | 09:37 AM
Super Slow SS's Avatar
x2 I did the same thing!
Old Sep 22, 2009 | 09:49 AM
vipvegas's Avatar
so your leaving them in the stock location and doing this?
Old Sep 22, 2009 | 09:54 AM
JAX04's Avatar
i was wondering if you put them over top of each other, or try to maintain the stock off set, one on front and one on back?
Old Sep 22, 2009 | 01:07 PM
No I moved one in front of the A/C condenser and reversed the wired to make it a pusher ... the other is still a puller on the other half of the radiator. Not in a sandwich formation, that's not good, air will get trapped and stay hot.
. . . _ _
. [ / / / / Engine on this side
. /_/ /_/ ] <~~Fan/ puller
. A/C Rad.
if that makes sense.
Old Sep 22, 2009 | 01:24 PM
IT_SS's Avatar
. . . _ _
. A/C Rad.
any pix? I'm interested in the setup, and off topic, what T-Stat?
Old Sep 22, 2009 | 01:26 PM
XtremeDime's Avatar
I dont think reversing the polarity on the fan will work that well, the fins are still tilted to draw are in. it would simply swirl the air
Old Sep 22, 2009 | 05:28 PM
i guess i have nothing to lose but to try both as a pusher setup.
has anybody tried it on the streets for hours and see any issues?
Old Sep 22, 2009 | 09:37 PM
1BAD_LS1's Avatar
Restricted User
I am going to try using them both as pushers.... but i tried it out befor install and they push about 1/2 reversed as normall... Setup wont be done for a while but ill keep updated!
Old Sep 23, 2009 | 05:34 PM
I'll be trying it also, and will also be keeping ya updated
Old Oct 11, 2009 | 01:46 PM
1BAD_LS1's Avatar
Restricted User
forgot to post my results of using the stock fans.... ya it didn't work...
but check the link in my sig.... I got a 16" fan that works awesome for like $50 from "Hot Rods USA" on ebay
