Anyone making 700rwhp on stock block 346/347ci single turbo
I dont know the casting on the heads, they are stock 99 TA heads. i upgraded the valvetrain, pushrods, springs, patriot golds. We where running 12psi with a T56 and a midwest 9". When we went up to 15psi and th400 (almost 900hp) i cracked a piston. New ERL block coming soon
#35
Is there a general rule of thumb for a compression/boost ratio on these motors? I am in the middle of building my 347 back up and with the parts I have, I estimate it will be at 9.1-9.3:1 compression at 9-10psi for the time being. Is there any danger to having "too low" compression on boost? I realize I may lose some power but I feel like the motor will be bombproof at that CR and boost.
#37
I'm going with the mpt70 here soon with all stock block for now. Going to keep it at about 8 psi for now as well. Well see how long the motor lasts. Shooting for 500 so I think I'll be safe.
#40
I think I'm a little shy of 700 but very close, I'm still running stock bottom including the timing chain, oil pump, crank, rods,rod bolts, block,pistons,&,rings. I have untouched 317 heads for lower compression,GM MLS head gaskets, & ARP head studs (just because I changed the heads). I know there has been quite a few that pushed this little, much more but I'm still working on a single didget slip with what I have at almost 3800#'s.
