Speartech LS9 Supercharger Swap!
#161
Interesting build!!! Any luck on solving the shifting/tq management problem? Check out the link below.
http://www.dashdaq.com/forum/viewtop...=1&t=475#p2510
#163
The LS9 supercharger unit is a new design roots type with 4 lobes which makes it more efficient. Very interesting.
Maybe instead of a roots type, GM should have done a TwinScrew setup like the new 3.3L Whipple kit Dragon Pro Race Engineering has for LS1/LS6/LS2/LS3/LS7 that fits under the stock hood. Its a pretty revolutionary system for our cars.
#164
9 Second Club/LS1TECH Sponsor
Finally! After a long delay we are back on the car.
Time to get the exhaust system straightened out.
I decided the best all around way to go would be a custom 'Y' and a single exhaust system out the back. There's just no real good way to try and do true duals with the setup I have.
I went with a Flowmaster 3" to 4" Y:
Along with a Mufflex 4" system with Magnaflow muffler:
Since the pipes from the headers to the Flowmaster Y would be completely custom, I bought a variety of 3" 90's, 45's, and a piece of straight so that we could come up with whatever was needed to make a high flow Y.
Here's what we came up with for the car:
And installed:
Not too close to the trans pan:
Withe Y finished and in place, I could then see what it would take to mate it to the rest of the Mufflex system. In this case I bought a 4" 45 and had it cut at just the right angle to mate up to the system:
Thanks to Kurt from RPM Transmissions for all of the custom cutting and welding to make the Y assembly. Some people just have an eye to be able to look at all of the pieces of pipe and know where to cut them so that they mate up at the correct angles. Kurt can definitely do that!
The relocated O2 bung on the passenger side header:
And the wideband O2 a little farther back:
The Magnaflow muffler installed:
The Mufflex system from the rear:
The car actually has more ground clearance than with the old non-header system:
The car should run much better now!
And installed:
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
#166
I took the car to Muncie Wednesday night to make a few passes with the new exhaust system.
It likes the new system!
Undoubtedly, I should have added the headers a long time ago, but it was kind of neat running 10's with stock manifolds.
The car went 10.22 @ 132. I made 4 passes, that was the best. The car felt good and consistent.
I'm 152.
The car is making about 9 - 9.5 pounds of boost.
NOW it's time for the smaller pulley!
I'm 152.
__________________
www.speartech.com
www.speartech.com
#174
Glad to see the headers and exhaust worked out for you John, we use that set up on all the larger cube swaps we do here, here are some pics of the NEW 2in MONSTER PRIMARY headers and the 3in y pipe and 3.5 in exhaust we are doing now, wonder if we could get a tenth or so out of the 2in primaries . below are the pics let us know if anyone needs any help with the exhaust on there 3rd gen ls swap.
Thanks,Bruce
Thanks,Bruce
#175
Thanks,Bruce
Thanks,Bruce
#180
The smaller pulley is rated at 3-4 psi increase, so I'm hoping for a realistic 2-3 psi gain.
__________________
www.speartech.com
www.speartech.com
