LQ4 build for boost, how much?
Keeping the above criterea in mind, what all would be needed to take my LS1 (from the 98 Formula in my sig) and convert it to handling a 76mm turbo and LOTS of boost, all while utilizing the LQ4 setup for budget purposes?
I know they are LS6 style heads and the larger 370 ci should allow for more displacement while running the lower/safer CR. But past that I don't know a whole lot.
What all would be needed? What would it cost part wise?
Most of what I mentinoed above and with a new block, balanced and blueprinted, built by HKE, I have ~5500 in the total shortblock assy.
So basically a well put together motor and a hellified tuner = big RWHP and no problems
What all from the LQ4 engine would I need exactly? Where is it the biggest money saver?
your LS1 cant go to a 370, but could be a 383 with a stroker kit. A 370 is a LQ4/9 with a stock crank(mostly but could be upgraded to aftermarket for extra $), forged rods and pistons, and bored cylinders. The iron block will hold up to 1000hp and the heads will "probably" push water befor the iron block fails.
The biggest money saver in a 370 is reusing the stock crank, that saves about 1k for the cost of an aftermarket one. You could always build a forged 347 which uses your LS1 stock crank with forged rods and pistons also.
Some have gone well over a 1000rwhp with the aluminum block, though most use a LS2 instead because they said to be superior to the ls1 block but the LS1 will handle 800+rwhp with no problems.
Any other info I might need to know or keep in mind?
But the block, crank, and heads that you have will work wonders for the power that you want. Blake is running a 98 LS1 block now.
I don't want to repeat anything that you already know, but feel free to give me a call if you've got any questions.
You think my TSP 5.3 stage 2.5 heads would be good? I know they flow good, but they helped bumped the compression way up, and thats exactly what I would want to stay away from if I go boosted with it. I probably would just play it more safe and go the LQ4 route with a stock crank, then forge everything else and go from there.
Two more questions;
1. What is the difference between the LQ4 and the LQ9?
2. How much can you get the LQ4 for? And how much would it cost all said and done to buy all the parts for the motor to take big boost?
Ideally I'd want to run a 76ish sized turbo as high as it safely could still on pump gas with meth injection and a big FMIC. Maybe if the turbo had boost left in it after that, run race gas to see what it would do.
[quote]You think my TSP 5.3 stage 2.5 heads would be good? I know they flow good, but they helped bumped the compression way up, and thats exactly what I would want to stay away from if I go boosted with it. I probably would just play it more safe and go the LQ4 route with a stock crank, then forge everything else and go from there.[/quote
Only reason I'd stick with the TSP heads you have is if you wanted to save costs and stick witht the LS1, but it seems you are leaning the right way and have no problem going the LQx route, and in that case use the 317s. Blake used his heads off the 5.3 with his new LS1 build and even milled the heads down more to try and raise the compression to the 9.0 range (can't remember the cc of his heads or the cc of his pistons off top of my head).
)A 76 is going to be just on the small size for a 364ci or 370ci. 78 to 81 would be best IMO. For what you want, I'd reccomend a Turbonetics TC 78 with a 1.15 divided turbine with an F1 wheel, 78mm inducer/108mm exducer. Biggest bonus is that it's not only relatively cheap, but it's also water cooled
As for prices, it really depends on how crazy you want to get with it, but you should have right around $5000 in a long block that'll take more than you could throw at it on pump gas! I'll PM you my motor build sheet.
Hopefully that helps
750-800 rwhp is no problem with the forged block and 317's since on a all stock LQ4 people are topping 600 and 650.
The cheap way is to buy a complete shortblock unless your doing the work yourself or know someone who does it cheap.
TSP's 370 starts a 2999.00:http://texas-speed.com/shop/item.asp?itemid=683
with all the options like upgraded diamond pistons, steel top ring, callies rods, eagle forged crank and main studs you still come in shy of 4000.
