Ignition advance per compression and boost?
Old Oct 11, 2009 | 09:45 AM
z28boysteve's Avatar
Default Ignition advance per compression and boost?
So right now I'm at a conservative as hell 16 degree peak advance at 11 PSI
Where should I be at 22 PSI with 8.45:1 compression? Did I pick too big a dish when I built my 402? -25CC
Old Oct 11, 2009 | 10:01 AM
otherwhitemeat's Avatar
You did get a little conservative with the compression.. Like I said in another post.. I think 23-24 deg. will make the most power...with C16 or Q16. This is where I'm at with my 400cid, 94m turbo, and same with my buddies ford 347, Pt88. Seem to like that timing at about that boost level.
With only 11psi, I would be running 30 degrees timing!
Old Oct 11, 2009 | 10:37 AM
Shawn @ VA Speed's Avatar
what fuel are you using?
Old Oct 11, 2009 | 01:30 PM
Was running 93 Pump, will be running some C16 Race fuel though this time around, tired of driving it on the street!
Old Oct 12, 2009 | 02:56 PM
Btw, How much power am I likely to gain moving from 16 degree to 22 degree peak advance assuming there is no detonation. (with 8.45:1 and race gas Im sure there won't be at 22PSI)
Old Oct 12, 2009 | 03:56 PM
98Z28CobraKiller's Avatar
Restricted User
One way to determine that is to put the car on the dyno and just raise the timing until you don't make anymore power or until you pick up knock on the sensor or see it in the plugs. The better way is to read plugs at the track.
There are way too many variables to just give you a number. The head design and valve angle, the cam (DCR), plugs, weight of the vehicle, amount of restriction in the exhaust, etc. No 2 cars are exactly the same.
Old Oct 12, 2009 | 04:15 PM
Not even a roundabout guess? My tuner said he picked up near 200 hp going from 14 degrees to 20
Old Oct 12, 2009 | 04:38 PM
200-250hp...maybe more
Old Oct 12, 2009 | 05:46 PM
ayousef's Avatar
I hope you guys are kidding about the last part though.
Old Oct 12, 2009 | 06:00 PM
Well he's probly making 600ish rwhp with his 11psi and 14? degs timing...and with 22-24 psi and 22-24degs timing he should put down around 850 rwhp and I know this from experience. Now that turbo, with a really good kit/combo, should put down about 950rwhp and a full racing set-up close or over a 1000rwhp max.... so if he has a good kit...turn up the boost, and really....if your going to 22psi just max it out cause it most likely go over 25psi b4 it's done.... Also he needs that timing turn UP to 22-24deg at full boost with c16/q16 and he will be nothing but smiles.....
Old Oct 12, 2009 | 06:40 PM
When I put a 4"DP and Charge Pipe and the PT3000 A2W intercooler on, I expect Ill gain a fair amount over the current 580RWHP (naturally) and then I can raise boost and add timing. Would like to see that 88 max out Wonder what the car is going to run when I pull 100lbs, put on skinnies, have a quicker ramp up on the timing, and 500 more rwhp from the 10.80s it runs now, thinking a low 9 when it's all said and done for the PT88. That would be very smiley indeed, just trying to figure out where to set my goals.
Old Oct 12, 2009 | 08:15 PM
Old Oct 12, 2009 | 08:39 PM
ayousef's Avatar
well if you guys were talking boost I wouldnt disagree, but ur tuner is telling you that youll pick up 200HP by bumping up the timing ONLY?
Old Oct 12, 2009 | 08:49 PM
We were talking both....but Yes picking up 200hp from timing is easy
Old Oct 13, 2009 | 12:18 AM
Only time and the dyno will tell! I'll be back from Iraq in 2 months, so in 3 months I should be done zapping and screwing it all back together. Btw saw one of you is from Dubai, how much does a car like mine, if it was mildly streetable, nicely modified and ran low 9s be worth over there?
Old Oct 13, 2009 | 04:56 PM
ayousef's Avatar
people would careless on how fast the car is in the 1/4 BUT, you're most likely going to get the how much HP question, and if its above 800rwhp, chances are you're up for a good sale.
PM me, and who knows what comes up
Old Oct 13, 2009 | 09:51 PM
LASTLS1's Avatar
6 Second Club Moderator
Over 18 lbs I run 13 degrees.
Old Oct 13, 2009 | 10:23 PM
'Trust''s Avatar
I picked up 80RWHP from a 3* difference. I run 20* on 101+meth, 16 on 93+meth.
Old Oct 14, 2009 | 02:42 AM
Oh crap, Well when I picked my heads, they were still so new nobody knew the fatigue point of them. Now they do, and I guess I'm a little late to find out, L92 heads dont hold up to turbo boost very well! ... Looks like low 9s even will be out the window as Ill have to keep the power down to around 850 RWHP to have any sort of margin of safety on this thing. So the question now is, what's safer, more boost less timing? or less boost more timing? if either put you at your same goal? which creates lower peak pressure?
Old Oct 14, 2009 | 12:33 PM
lt170chevelle's Avatar
Wouldnt you think more timing and lower boost would be optimal? Im thinking at an effieciency standpoint. I guess it just depends on the setup.Sorry im full of questions and no help lol
