High Compression Turbo Cars and Timing...
For those you who run 9.0:1 K/R and up, how much timing and boost are you running with it. Forged short blocks ofcourse.
Restricted User
Looks about right. You guys get some 100 octane at the pump, correct?
I ran about that much timing on 93 oct and 12:1 compression N/A. 8 PSI isn't that much and the compression has been lowered a bit.
Different combos can tolerate different amounts of timing. The vehicle weight, SCR, cam (DCR), gearing and exhaust all come into play.
Pump and Meth Tune... C/R is 9.7:1 with 12* timing and 14lbs does this sound about right? Or am I leaving power on the table? I'm running twin 57mm garretts on a forged short block with -13.7cc diamonds. Feel free to guess at my new numbers!
First off I think turbo is alot different as far as timing vs boost and c/r. Further more I know I'm leaving alot of power on the table since I'm still running stock cam, but I'd like to make the most I can on boost and timing safely via 91 and meth. I'm suspicious that I have sum more power left untapped.
