explain this
Old Dec 5, 2003 | 10:54 PM
Justin98TransAm's Avatar
Default explain this
dyno before vortech install. 312HP
dyno after vortech install. 312HP
boost guage read 9lbs, the boost guage is tee'd in to the brake booster line off the back of the intake manifold.
Old Dec 5, 2003 | 11:52 PM
69firebird's Avatar
youve got a leak somewhere, and it sounds like it is holding your bypass valve and the blower cant make any boost
ed
Old Dec 6, 2003 | 12:01 AM
ed
if the bypass valve was open wouldn't it not show any boost on the boost guage, since it connected to the back of the manifold?
Old Dec 6, 2003 | 12:14 AM
69firebird's Avatar
youd think so, but what else would explain that?
what kind of cam and timing are you running? you could have the wrong cam i supose and all the boost is leaking out with the overlap, but there would still be some power gain.
ed
Old Dec 6, 2003 | 12:23 AM
ed
stock 98 cam..
Old Dec 6, 2003 | 03:03 AM
ta12sec's Avatar
Im thinking major intake gasket leak, maybe........
Does the car feel faster,
Old Dec 6, 2003 | 07:14 AM
Crunch's Avatar
HAHA!
How about this:
Before my Vortech install: 405RWHP
After Vortech install: 365RWHP
Now, after some SERIOUS dyno tuning, better injectors, better fuel pump:
521.9RWHP
GET IT TUNED.
Old Dec 6, 2003 | 09:42 AM
Whistler's Avatar
Sawzall and Welder Mod
Yeah, it might be lean as hell, I'd get it tuned.
Old Dec 6, 2003 | 10:26 AM
MIGHTYMOUSE's Avatar
show us the two graphs.. any chance they are the same one?
Old Dec 6, 2003 | 11:40 AM
Noyzee's Avatar
8 second mod
Tune my friend tune!!!
Old Dec 6, 2003 | 11:57 AM
69firebird's Avatar
still there should be some noticible difference
Old Dec 6, 2003 | 12:27 PM
Here are Both Dyno Graphs, the A/F was 11.5:1 the whole way across the board after vortech install, so it's actually a little rich, but not enough to kill over 100 horse power. I just copied my friends timing table from his 99 vortech car, gonna see if that makes a difference.
waring large pics so you can see the graphs.
before vortech
http://www.fbodypages.com/justin98tr...yno/before.jpg
after vortech
http://www.fbodypages.com/justin98tr...dyno/after.jpg
Old Dec 6, 2003 | 01:32 PM
MYTURBOT/A's Avatar
If you had a leak in the piping you would not see 9psi probaly would not see any boost. Could be a head gasket but we`ll hope not. are you still running cats?
Old Dec 6, 2003 | 01:40 PM
Silverchickn's Avatar
I would also think it would be a good idea to do a compression test on all of the cylinders. Dont get me wrong I would hate for you to have some compression issues but its another place to look. Did you try Autotap it and see if there was any knock retard. That might have also took some power.
Old Dec 6, 2003 | 02:08 PM
the car is backfiring, i'm using the stock pully, mods are in my sig. boost guage read zero with car off. I had Autotap hooked up on the vortech dyno run, here are the logs for both runs on the graph, blue is run2 read is run1
http://www.fbodypages.com/justin98transam/atap/run1.csv
http://www.fbodypages.com/justin98transam/atap/run2.csv
