I suppose its time to make a build thread...eBay kit!
Old Dec 24, 2009 | 09:58 PM
  #61
XtremeDime's Avatar
Im not worried about the lifters @ 6psi, shouldnt really be an issue unless something goes horribly wrong lol
  #62
XtremeDime's Avatar
Originally Posted by ModularTurbo
The ONLY turbo F body in Alaska LOL
Lol ya, youre one of the only shops that didnt question Alaska being a state haha
Old Dec 24, 2009 | 10:35 PM
  #63
1BAD_LS1's Avatar
Restricted User
Originally Posted by XtremeDime
Dont jixx me you son of a bitch lol
They might make it till you buy a new clutch and rear... but ill be keeping an eye on your thread
Alaska is a state???? LMAO, JP!!!!!!!!!
Old Dec 27, 2009 | 10:01 PM
  #64
-Q-'s Avatar
-Q-
Hey man, what clutch are you going with? I was looking at a few of the same ones you were in the forum classifieds...still haven't settled on one yet...
Old Dec 27, 2009 | 11:55 PM
  #65
XtremeDime's Avatar
Im using the stocker til it goes out! lol
Old Dec 29, 2009 | 12:50 AM
  #66
-Q-'s Avatar
-Q-
Good lord! You'll blow through that clutch pulling out of the parking lot!
Old Dec 30, 2009 | 05:33 PM
  #67
tallreyes's Avatar
is it required to change THE VALVE TRAIN OR CAN I GET AWAY WITH STOCK SETUP?
Old Dec 30, 2009 | 05:39 PM
  #68
XtremeDime's Avatar
From what I was told if you go over 6psi it can cause the valves to float with stock springs
Old Dec 30, 2009 | 05:42 PM
  #69
tallreyes's Avatar
ok can i just change springs or do i need to replace more stuff thanks for the help BTW
Old Dec 30, 2009 | 05:48 PM
  #70
XtremeDime's Avatar
Should also change out pushrods to hardened or chromemoly to keep from bending the stockers with the added tension of the new springs.
Old Dec 30, 2009 | 05:51 PM
  #71
tallreyes's Avatar
awesome thanks what about injectors? how big do i go?
Old Dec 30, 2009 | 05:52 PM
  #72
XtremeDime's Avatar
What are you goals? I have 55# ones, should last me for like 600whp or so
Old Dec 30, 2009 | 06:01 PM
  #73
tallreyes's Avatar
600 hundred would be plenty wanting around 500 rwhp minimum was wanting a twin turbo setup but cant find a chap enough kit
Old Dec 30, 2009 | 06:06 PM
  #74
XtremeDime's Avatar
Bah, if youre only wanting 600ish you can do that with a decent single setup. A t70 would spool faster but a t76 would be a better option if you want to run more than 600, atleast in the long run.
Old Dec 30, 2009 | 06:14 PM
  #75
tallreyes's Avatar
that sounds great ya will most def want more later just around six for now so i can just buy a piping kit off ebay and get a t76 turbo and wastegate.
Old Dec 30, 2009 | 06:19 PM
  #76
XtremeDime's Avatar
A better option might be to talk to kentucky turbo or wait for Modular to come out with their kit. The ebay kit has been a pain in the *** since the start and ive probably spent about 500$ welding things, buying new parts for other things so itll work. Its really sucked.
Old Dec 30, 2009 | 06:20 PM
  #77
tallreyes's Avatar
sounds good thanks for thehelp i will give them a call
Old Dec 30, 2009 | 06:25 PM
  #78
MUSTANGBRKR02's Avatar
Build the kit yourself. This kit is a PITA!
So i have a V-band. I ended up taking the pieces to work and using the bench grinder to massage the flanges down to about .170 each from .220 on one and .208 on the other. There is more than enough flange to still be reliable. If that didn't work i was just going to grind more. I should be starting mine this weekend.
Old Dec 30, 2009 | 06:31 PM
  #79
tallreyes's Avatar
i just dont have the right metal fabbing equipment or i would
  #80
XtremeDime's Avatar
Good to hear! So the OBX vbands didnt work out either? FML.
