Meth vs Nitrous for FI
Old Oct 22, 2009 | 08:20 AM
98Camarod's Avatar
Default Meth vs Nitrous for FI
I think we all know the benefits of using meth and what has to be done as far as tuning when using meth. But my question is, since the nitrous can be had for a cheaper price, what needs to be done as far as tuning, ie afr, timing, boost? Also, where would be the best place for nozzle location?
Old Oct 22, 2009 | 08:34 AM
BIG_MIKE2005's Avatar
Those 2 things have completely different effects as far as I know. The meth is like adding a higher octane to deter detonation under boost. Nitrous does not do this. Hence why people run stand alone fuel cells with race gas for when they spray or run a little higher octane in tank when spraying nitrous. And as far as I know everyone suggests tuning without the meth as well. Then sprayin the meth on top if needed. Only time I have seens cars tuned with meth is for basically race only applications. Or at least thats what I have found to be suggested.
So I'm a little confused about your meth tuning comments. Now I have heard of nitrous being used to help turbo spooling in certain applications. But I do not believe it is possible to use nitrous in place of meth since they do not serve the same purpose.
Old Oct 22, 2009 | 08:35 AM
pwrtrip75's Avatar
I sprayed a 50 shot into mine, didnt need to do a thing different to the tune. When it was a wet shot it fouled the plugs out. So I just diconnected the fuel solenoid and left it. Nozzle is right after the TB in the intake plenum. Seems to work fine.
Old Oct 22, 2009 | 08:44 AM
I believe he is asking if he can use nitrous in place of meth with the same results since nitrous is cheaper.
OP, correct me if I mis-read what you were asking.
Old Oct 22, 2009 | 08:46 AM
98Camarod's Avatar
Meth is used to lower the IAT's, so you can have your tune without meth and then tune for meth like you said. But there is a table for IAT spark advance which allows you to add or remove timing for different IAT's.
My concern is for when spraying, what is the target afr and timing suggestions.
Old Oct 22, 2009 | 08:52 AM
98Camarod's Avatar
So your basically using a dry shot, do you have a maf? What gain did you see with the 50 shot? What afr and timing are you running with the 50 shot?
Old Oct 22, 2009 | 09:18 AM
pwrtrip75's Avatar
5.3L 8.6:1 comp. 11.4-11.6: AFR. Timing set at 19* No MAF.
15psi boost
w/o nitrous 10.5x's @ 128
w/ 50 shot 10.30's @ 131
My converter is a TCI streetfighter 4000 stall rebuilt by Coan. They told me to not even bother putting it back it cause it will never hold up. Hughes built me one and I had problems and sent it back so I threw the TCI back in. It works ok but im sure its losing some.
Old Oct 22, 2009 | 09:30 AM
Sluggish's Avatar
Meth is cheaper then Nitrous as far as how long it last and how much it cost. Meth is about 3 dollars a gallon and 5 gallons lasted me a very long time running 100% meth. It reduces iat, increase octane and acts as extra fuel. I have my nozzle after my BOV but before my iat sensor.
Old Oct 22, 2009 | 09:34 AM
'Trust''s Avatar
My methanol is $5/gal and I mix it, most n2o is $2-5/lb, I don't really see it being cheaper.
Old Oct 22, 2009 | 09:36 AM
98Camarod's Avatar
I was referring to buying the system used or new for that matter. I can get a bottle filled for less than 20 bucks since my uncle owns a refilling station.
Old Oct 22, 2009 | 09:49 AM
Ok, I'm on the same page now I think. Your weighing options between meth w/more boost or just adding a nitrous kit right? The way it was worded in the OP confused me a little.
I'd say actually in the long run meth would be the better option. Especially with a turbo where you can run a boost controller & change boost levels whenever you want to take advantage of the meth. Depending on how hard you push it while running the meth will determine how much is used. Like Trust said, a full tank of meth up front can last a while & a 5 gallon container could last you months. I think you'd run through more nitrous than meth honestly & eventually the nitrous would end up costing more to keep on hand than the meth.
But thats just my opinion.
Old Oct 22, 2009 | 09:57 AM
Sluggish's Avatar
How long does $40 dollars of n2o last and how long does $40 dollars of Meth last. Meth is cheaper. A bottle would last me 4-8 passes, 5 gallons of meth has lasted me around 8 months.
Old Oct 22, 2009 | 10:33 AM
MUSTANGBRKR02's Avatar
Meth is much cheaper than nitrous. You can also run washer fluid or mix meth as stated which to be alot less than nitrous.
Also driving around with a nitrous bottle in your car can be dangerous if it gets to hot and exceeds pressure ratings.
Old Oct 23, 2009 | 12:05 AM
98Camarod's Avatar
Good point. I was thinking initial cost not really long term which was stupid of me. Even though I get the discount, I don't see it being a viable option now.
Old Oct 23, 2009 | 06:38 AM
chuntington101's Avatar
i say do both!
Meth to help reduce IAT for starters then a 50shot of N2O to REALLY get the temps down! would be like having an A2W setup with an ice box but whenever you wanted it! lol
Chris.
Old Oct 23, 2009 | 08:22 AM
YSILT1's Avatar
Nitrous Express claims with a 100shot every 10 seconds you use 1lb. At least this is what they have told me.
Old Oct 23, 2009 | 09:17 AM
jason02Z's Avatar
Originally Posted by chuntington101
i say do both!
Chris.
haha thats what i was gonna say..meth nozzle in front of the turbo for lower IAT and octane. and spray a 50 shot through a plate/nozzle, the turbo will double it in tq
Old Oct 23, 2009 | 10:37 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Apples vs oranges buddy.. Meth increases octane, and adds fuel which decreases detonation. Nitrous leans out the mixture and effectively increases detonation possibility. The only thing that they have in common is they both bring IATs down. A meth kit is not at all a big initial hit. You can get a very complete and comprehensive brand new kit for $500-600. Whats a new nitrous kit cost again? I average 1 gallon of meth every 1000 miles. I just filled up my 5 gallon reserve for $18 a couple weeks ago. That will most likely last me a year. Meth FTW IMO
Old Oct 23, 2009 | 06:22 PM
LS1BLKSS's Avatar
Banned Village Idiot
15psi boost
nice times do you spray off the line?
Old Oct 29, 2009 | 10:48 AM
bottlefed370's Avatar
Im building a gt47-88mm 377, truck manifold front mount and was planning on spraying a 100 shot with meth just for the hell of it.
