Wsss6 - MPT70 Front Mount Build
i would do an ls6 cam at least as they can be found for $80-100 in the classifieds. i dont think youll be able to drain into the timing cover with the stock pulley. i have an asp on mine it is very close to the pulley. as for the bumper support, i cut the center off with a cutoff wheel and cleaned it with a grinder, then welded some spacers and some 1x1 stock across the top to mount the intercooler to.
build looks good man, keep it up
Looks pretty good. Doug's MR2 decided it didn't need one of its exhaust valves and tried to get rid of it. lol.
He's pissed if you can't tell. His new shortblock just came in though and he's going to do some CFD and design his own optimized exhaust manifold. Here's his "other" car.
Space is limited in my basement so I had to take the last picture from behind a screened window, who put that office there?
Anyway, I have a few days off next week so hopefully I should be able to get a lot done.
I plan on installing that bracket in the next week and snapping some pics. I am at about the same point as you are with my build. I just tapped my front cover and am itching to put it together and take it for a spin.
What are you doing for tuning?
For tuning I bought EFI Live off a member here with a couple licenses left, so I'll try and do my own tuning. Doug is also the engine leader for our formula car team at school and knows a lot about tuning, he offered to give me a hand.
What were you planning on doing?
and here you can see about how big the -10 fitting and the pushlock hose i used is
im interested to know if it works as well
I have HPT, but Frost will be tuning it for me and i will fine tweak it when needed.
Did you end up getting a cam?
