Wsss6 - MPT70 Front Mount Build
#81
At the time of that picture, yes, I had the bracket on and the cruise control hooked up at the same time. My intercooler pipes now go through the spot my cruise control box was so I have since removed it. Have you tried loosening the three bolts that hold on the bracket and trying to rotate it over a bit? The holes should be slightly overdrilled so it should wiggle a little until they're all tight. Let me know if that works for you.
#82
yeah i got it on there, had to do a little modding to the bracket lmao, wallerd out two of the holes to rotate it over so i have plenty of room. I plan on keepin my cruise so i had to do something, got it all painted up now, brand new alternator too. was gonna put it on this weekend but me, the yagerbombs, the 4 wheeler, and the dirt got into a bit of a,,,,,,, altercation. gonna have to wait another weekend lol
#83
lol, yeah, too often booze gets in the way of life... or is it the other way around? ![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Anywho, after a long (un-deserved) break from working on my car I finally got back to it today. I had some parts come in and I chased some others down.
Put a filter on the oil feed line.
![](http://i181.photobucket.com/albums/x212/Wsss6/0113101811-00.jpg)
This little %&^*ard was hard to find. (Its a plug for my oil level sensor) BTW, my dp doesn't hang this low, I moved it for the picture.
![](http://i181.photobucket.com/albums/x212/Wsss6/0119102004-00.jpg)
I thought after all that grief I finally had my drain line figured out...
... but even after a couple good tugs it came out a half inch too short. That's the story of my life.
![](http://i181.photobucket.com/albums/x212/Wsss6/0119102059-00.jpg)
I had extra hose though and I figured it out. Here's everything in there.
![](http://i181.photobucket.com/albums/x212/Wsss6/0119102205-00.jpg)
Tomorrow I'll put on my belt and radiator and get some fluids in there. Should be all set to start it up pending a decent tune. I looked around for a file repository but didn't see anything I liked that was in the format EFI Live uses. Anyone know any good places to look or should I just start from scratch?
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
#85
I bet under 12 years of grit and grime there's a shiny aluminum flange somewhere.
#87
any updates Jared? for those of yall who got an Alt Relocation Bracket from Wsss6, the belt i ended up goin with is 73.5 inches long or 1867 mm, *EDIT* this belt length for 25% underdrive crank pulley!
#88
Good eye on the hole in the dp, I fixed that up right quick. I finally got around to getting my car out of my parents garage and I think I'm there. I've got some tidying up to do still (like getting an upper radiator shroud) but its good to go for the moment. I was convinced to try and start it on the stock tune and to my suprise it turned over a few times, started, and idled fine until I shut it off. I'm getting my tranny rebuilt by a buddy so I can't really go anywhere yet but I'm happy with how everything turned out. No video or numbers, but here's a couple pictures I thought were cool.
![](http://i181.photobucket.com/albums/x212/Wsss6/0212100855-00.jpg)
![](http://i181.photobucket.com/albums/x212/Wsss6/0212100857-00.jpg)
I saw this as I was visiting my girl in Springfield...
![](http://i181.photobucket.com/albums/x212/Wsss6/0212101311-00.jpg)
That's a lot of truck.
Maybe I should post this question in the tuning section, but i was reading the tutorials in EFI Live and it suggested switching to a 2002 operating system. I downloaded the 2002 OS from their website but haven't done anything with it yet. Reading further in the tutorials it said for boost I should use a custom OS they have. What's your guy's take on this? Should I go with the custom OS from EFI Live? Can I just load these things onto my stock computer? The tutorials aren't too clear on what hardware is necessary. I realize custom adjusting will be necessary but I want to make sure I'm starting from the right square in the first place.
#90
#91
Thanks for the input, that's what I was thinkin. I posted up the question in the tuning section so hopefully someone with experience using a custom OS on EFI Live will see it and offer some insight.
#97
I actually never finished tuning the car so I have no idea. I took a summer job in Wichita and left the car back home so I haven't seen or touched it in a few months. I need a dd for my last year of school so I'll probably end up returning it to stock and put all of the turbo stuff back on when I can get myself something else to drive around every day. Sorry for the let down, but such is life.
