do i need to brace the turbo flange?
I was just woundering what every one else is doing.
Thanks, Mike
I might have to do motor plates since my aftermarket bmr k frame wont allow solid motor mounts, if its mounted to the body you have to worry about cracking with the motor flexing.
My new setup I used a T6 flange from racepartsolutions that has a bolt on mounting bracket...
Well i am hoping to start fabing up the hot side pipes next week. See what i can come will work best
Thanks for your input guys
even though it probably doesnt need it, I had smi fab make me a mount that should help the pipes a bit.and it only cost 20 bucks. the idea is to weld or bolt it straight to the frame. I'll see how it goes
he said he had solid mounts which are almost as good as plates
I need to do something with my 50lb turbo...
