So im thinking about boosted.
Old Oct 28, 2009 | 04:03 AM
ws6driv3r's Avatar
Default So im thinking about boosted.
Which route do you guys think would be better to go with for a dialy driven a4 vehicle an sts rearmount kit or a d1sc? every thing on the car except headers and full exhaust is stock.
Old Oct 28, 2009 | 05:33 AM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com....html?item=798
I can just about guarantee you to have far fewer problems with the above kit. Bob
Old Oct 28, 2009 | 07:01 AM
98Z28CobraKiller's Avatar
Restricted User
If rear mount turbo is the only turbo option, then I agree with Bob.
Old Oct 28, 2009 | 07:12 AM
Super Slow SS's Avatar
3rd, I agree vs the rear mount, and i have had one, plus you don't lose money on your already purchased exhaust
Old Oct 28, 2009 | 10:44 AM
The Fugitive's Avatar
okay just to be clear your exhaust is stock but you have headers? Or you have upgrades to the engine and all the exhaust is stock?
Old Oct 28, 2009 | 10:51 AM
sujomatt's Avatar
sounds like everything is stock except for exhaust, id do a procharger if i were u.. my STS kit was a giant PITA..
Old Oct 28, 2009 | 10:53 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
+1 for procharger
Old Oct 28, 2009 | 11:41 AM
youngrigo's Avatar
Procharger all the way......
Old Oct 29, 2009 | 09:45 PM
extremetoy's Avatar
i had a rear mount turbo on my lsx s10 and recently moved the same turbo up front... it was a little laggier, got dirty since it was right near the road and had to have an oil return pump... but it worked really well and i didn't really have any problems with it, not sure why people are so against them here... i have no experience with prochargers and don't plan on it, i dont see anything wrong with turbos... there pretty simple
Old Oct 29, 2009 | 10:15 PM
chasgiv3's Avatar
There's definitely some cons with an up front Turbo kit. If you truly need your car to be a daily driver then I really wouldn't do too many modifications to it. Adding any significant HP without really planning on all the weakpoints means you're headed for a huge disappointment. I've heard all the stories...I'm only adding a 100HP that's it and I'm done. What I like about Turbos in general is that I can control boost with an electronic controller. Hey I'm running pump gas today let's go 12 PSI only. Hey I'm at the track with C16 I'll run 20 PSI. Changing pulleys or cogs just isn't my cup of tea for flexibility. Another thing to consider is that Turbos will quiet down your free flowing exhaust. If you like the loud in your face sound then definitely go supercharger. I couldn't take the highway in mine. The drone was way too much for me. Capping the exhaust with mufflers that got her quiet lost me enough HP to make me crazy. But Turbos are definitely expensive so if you're tight on cash then you may want a blower instead. But be forewarned that once you go down this slippery slope of the MORE HP syndrome you'll be fixing the next weak link. Once all the links have been addressed then you'll need more HP. I started in 1998 November when I picked up the car and told my wife it had enough power and I didn't really need to modify it at all. March of 1999 I did heads and cam with my local friends like Z8's and ProStockJon.
Good Luck
Old Oct 29, 2009 | 10:25 PM
lmt0705's Avatar
procharger + Bob from EPP = great price and reliable performance!
Old Oct 29, 2009 | 10:33 PM
elias_799's Avatar
i would defiantly go with a procharger over a the sts system.
the whole point of having a car turbocharged is to make power as efficiently as possible. and with the turbo mounted in the rear the whole point is killed.
if you need more info on why the turbocharger efficiency is lost feel free to ask.
