Starting the maggie install on my SS
So does everything off the GTO kit work just fine in terms of snout and belt alignment? Would a kit for an LS1 or LS2 GTO fit or do you specifically have to look for one off certain years?
Also is there a way to run an 8 rib setup or does everyone stick with the 6 rib?
Thanks for the help!
I got a little more work done on the SS today as I installed a Volant CAI kit now all thats needed is some couplers and some polished pipe piece which should be easy to do since I"m running with a SD tune now.
Where did you get the maggie from ?
thanks Warren
I really like your blower better than mine. I like how the intercooler hoses on yours come out the front instead of the back. Yours looks much cleaner and it's much more servicable that way. Also I like how you came straight out of the blower with the throttle body. Mine has this aluminum piece. I think I may get rid of it and go with a longer piece of hose because currently it doesn't fit well with the short hose.
https://ls1tech.com/forums/album.php...ictureid=29120
Looks good man. You're gonna love it.
You have any pics of your setup .
www.speartech.com
comapy projects
stage 2
BTW: Im doing maggie install on my 88 GTA trans am, ill be doing a cam at the same time, and I have bolt ons and no cats.
Ill post pics when I tear into it.
www.speartech.com
comapy projects
stage 2
https://ls1tech.com/forums/forced-in...o-numbers.html
Numbers are going to change soon, just built the bottom end,installed LS6 heads and just got a 2.9" pulley to put on......
