Project Turbo LS2/350z begins.
#85
And id suggest solid engine mounts to anyone. I can barely tell they are in there..I almost forgot I had them at first. You get nice feedback from the steering wheel.
#87
Man that things sounds mean as hell. All the ricers will be wondering what kind of V6 you have when you pull into the parking lot. LOL.
You gonna run a muffler or leave the DP open?
#88
4" cutout out back and then hooked up to the stock exhaust. =) The only giveaway will be the fuel pump other than that it should be pretty quiet with the CO closed.
#92
Not only does it fit..but you can't even see it. I cut the top of my old over flow tank and it fits right over the turbo. Once the turbo blanket is on it will be completely hidden and wont melt.
![Name: IMG00199-20100328-2235.jpg
Size: 68.4 KB](https://ls1tech.com/forums/attachments/forced-induction/620380d1501357888-project-turbo-ls2-350z-begins-img00199-20100328-2235.jpg)
![Name: IMG00203-20100328-2235.jpg
Size: 73.0 KB](https://ls1tech.com/forums/attachments/forced-induction/620381d1501357888-project-turbo-ls2-350z-begins-img00203-20100328-2235.jpg)
