Cost of the C5R?
Old Dec 9, 2003 | 10:36 PM
buschman's Avatar
Default Cost of the C5R?
I'm seeing more and more people use them, which I' really excited about. But everyone is treating the cost like it's top secret information. What are C5R short and long blocks going for?
Mike
Old Dec 9, 2003 | 10:39 PM
XLR8NSS's Avatar
Adkoonerstrator
The block alone, is over $6000. That is just for the block with main caps.
Old Dec 10, 2003 | 12:44 AM
Billy the Great's Avatar
i think i saw someone say that a set of c5r heads finished are in the neighborhood of 11 g's but they flow like 400 cfm. mayeb colonel or someone else who runs them could chime in here
Old Dec 10, 2003 | 12:52 AM
jstpsi's Avatar
wow 11gs for a set of heads, and 6 g's for the block. You could have a pat musi 1000 hp bigblock with fuel injection for all that money. Still the ring of a
c5r is nice. By the way ive seen them complete for 20k and thats a good deal....
Old Dec 10, 2003 | 01:18 PM
JordonMusser's Avatar
or get a REAL SBC little M based 434ci small block, and make 650+rwhp NA with off the shelf parts
Old Dec 10, 2003 | 02:12 PM
Scalpel's Avatar
I can get the C5R, BLOCK only, for $6125 shipped, dealer cost
Old Dec 10, 2003 | 02:15 PM
Scalpel's Avatar
I bet it wouldn't make 20+ MPG on the highway though
How much do those motors you suggested cost? I know nothing of their prices.
Old Dec 10, 2003 | 02:34 PM
actually, there is no reason why it wouldnt get 20+mpg. the latest racing heads for SBCs have VERY effcient chambers, and not like you are gonna put a carb on it or anything
there is a guy on CZ28.com with a 383ci LT1 with good heads, that made 580rwhp NA, and got ~20mpg on the highway. NA motors get bettery fuel economy from what I have found, due to compression mainly. my turbo motor is 8.8:1, vs my old NA motor that was 12:1.
Old Dec 10, 2003 | 05:00 PM
Scalpel's Avatar
Sweet, I assumed that they were running carburated setups.
Old Dec 12, 2003 | 09:55 PM
Bryan Wilkinson's Avatar
Default Exact cost of C5-R setup
You can purchase the C5-R block at Scoggin Dickey www.sdpc2000.com for $6200.00
The crank, will need to be a 4.00" crank,
You can use Lunati, $2200(Forged), Scat, $2200(Forged), Modex $2800 (Billet), there are others like Oliver ($3000)etc...
You will need to use, 6.100 or 6.125 rods. As everyone is using 6.125, the6.100 is a better choice because you can lower the wrist pin and have more piston surface thickness for things like blower, and nitrous. Rods will run from $500-$1500. Do not use Alumunum, These will stretch when exposed to heat unless this is a race application.
Now to answer the myth on the C5-R heads, They do flow 100 cfm over a stock ls6. however, there are a number of complications when using them, first cost is $1200 per head and they are unfinished. SPDC2000.com, then you will spend about $2200 on machine work to get them done. Bill Cradock of BCE in Nevada is the only choice for machine work on these heads. Do not believe anyone else on this. You have to have experience with the heads in order to do a good job on them and at $5000 a set (And that is the real cost) you want an expert doing this.
On to the problems. These heads do not work with the stock manifold. You have to use a sheet metal intake and they are about $2500, More Performance can have them made as well as LS1speed.com.
If you are going to buy this block, do not skimp on the internals.
Go to Katechengines.com, they developed the internals for this block in the C5-R racing program for GM, before Pratt and Miller took it over,
Get the Moldex Billet Crank, Carillo Rods, and Go to Diamond to get the pistons, Chris at Diamond used to work for Katech.
The is nothing wrong with Lunati, or any of the other companies, and they are good parts, but they are not the same standard as these parts. Carillo makes the undisputed best Connecting Rod on the planet. PERIOD. Billet will outlast forged any day of the week in any race. You could use any piston, but the guy who helped develop the Race block internals, started his own pistong company.Hmmm.
I been through this so if you have any questions and want the facts, you can email me at lunapark@perigee.net
Hope this helps
Bryan
Old Dec 12, 2003 | 10:13 PM
FastBlackTA's Avatar
c5r blocks are pretty pricy these days, hopefully they will come down in the future
I chose a resleaved block for my 427 engine build....just need to finish it first . For me, the c5r was overkill even for the dp nitrous shot i'll be using. remember, for the majority of us, the block breakage is rarely a problem....i'm much more worried about lifting a head.
