Meth injection??
My question is, Is there a difference between the various meth injection kits, Is one better than another and most importantly are there any I simply need to just stay away from.
I was thinking about going with the AEM kit from JEGS.
Any input would be greatly appreciated up front.
Snow= very simple. Start psi, end psi, and its just a gradual ramp. 2 *****, very simply
), but we have some systems specifically geared for the LSX engines and GM sensors. The simple comment is right on the mark. No matter how advanced a controller is, if you need to be an MIT grad to use it, there's a problem. We have several vendors on this site that know our stuff pretty well. Try giving AFR or TSP a call. LG has used our stuff in the past as well.
Call me anytime you have any questions about meth-injection in general too.
Things to consider:
What size tank do you need? Larger ones are designed to be trunk mounted.
How much boost do you plan on running? Get a controller that is designed to handle that much.
Do you want/need another display in the cockpit? Some have one, some do not.
Do you want a simple control system, or are you into the more complex but more flexible systems?
Make sure you have a low fluid detection system in place, at the very least.
Go with the slightly more expensive progressive controller, which injects more fluid as boost increases.
Someone mentioned pure meth vs. the 50/50 spray.
What are the pros and cons of both under high boost. Say 12-28lbs.
My tune won't be super aggressive since it's going to be a street/strip car.
Many people recomend pure meth, and that can be very effective. We recomend 50/50 for a few reasons:
It's safe. Pure meth has a low flash point and it is possible to get a back fire into the intake. It's not common, but it is possible. Additionaly, pure meth burns clear. You can only see the radiant heat from a methanol flame in most cases. So be very careful there. The fumes are very bad for you too, specifically your optic nerve.
Water actually absorbs a lot more heat than methanol. In fact it absorbs about twice as much before it is evaporated. So from an exhuast valve POV, water is useful.
It's cheaper. A lot of our customers are using the technology not just because of how effective it is but because of how cost effective it is. Some of our customers also inject at a rate of about 2000CC/MN
50/50 water meth will generally provide more detonation resistance than most people need anyway, and its easy to get. Many people just use -20F washer fluid because it is 1/3rd methanol, 2/3rds water and some blue dye. Hard to beat 2 bucks a gallon.Also, in a lot of testing, 50/50 seemed to work best in very high stress environments like supercharged high altatude fighter planes.
Now a lot of people have done great on pure meth or some other ratio, and that is fine, just be careful.
