FI Cam spec review
Old 11-10-2009, 01:40 PM
1INSANEGTO's Avatar
Default FI Cam spec review
408ci, AFR 225's, F-1R Procharger.
Cam Specs
.234/.246 .598/.614 114+3
Thoughts?
Old 11-10-2009, 01:49 PM
LS1Tech Sponsor
Superman09's Avatar
from the blower cam info I've been researching and such it sounds right on the money. I had one spec'd for a stock 346 and it was about the same ballpark, but less duration, same 12 split though, which is understandable for your cubes having more duration. Sounds about perfect to me for the set-up!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 11-10-2009, 02:08 PM
1INSANEGTO's Avatar
I can't wait for this all to come togethere
Old 11-10-2009, 02:15 PM
airforcemanss's Avatar
is the f1r head unit more for low end? i came across a thread where that unit was discussed. if that is the case, why are you using that headunit on a 408 instead of a f1a or f2? either way please post a graph when do you think she'll be up an running?
Old 11-10-2009, 02:16 PM
1INSANEGTO's Avatar
I hope everything will be up and running in DEC or 1st of the year.
Old 11-10-2009, 09:31 PM
DeltaT's Avatar
Almost the exact numbers I ended up with for my 434/AFR 235cc/YSi setup, 239/246 on 115.
Yours should rip.
Jim
Old 11-11-2009, 07:42 AM
1INSANEGTO's Avatar
DeltaT what did you end up making?
Old 11-11-2009, 10:15 AM
Restricted User
98Z28CobraKiller's Avatar
Yours should rip.
Jim
AFR 235cc heads? You know something that I dont know?
Old 11-11-2009, 06:18 PM
DeltaT's Avatar
Not an LSX motor, SBC. And I am still in the build so I don't have numbers yet.
Jim
Old 11-11-2009, 07:14 PM
TT-TECH Veteran
Inspector12's Avatar
Running a 238 254 in my 346 F1R car it works. You will make good power with it.
Old 11-11-2009, 08:31 PM
LS1Tech Sponsor
Superman09's Avatar
Could you post some vids? I'd love to hear that combo at idle!!!!
__________________
Old 11-11-2009, 09:35 PM
TT-TECH Veteran
Sounds stock LOL! I'll try to get one of it for you to hear.
Quick Reply: FI Cam spec review
