Finally started the twin turbo project!
All that's left now is to get to the track and see if I can get in the 9s
And I want to build a catch can for it.Frank
I run my twin 70s down to 8 psi no problem with twin 38mm turbosmart gates.
But like I said I am sure now with the bigger gate this will be a lot less of an issue.
This evening is the big test drive since the rain is finally out of here! I'm pretty confident there will be no more boost control issues.
Ya I understand sometimes the decision gets made for you even if you want to route things differently.
Either Way I am sure it will be good now !
Got some new shoes for the 17s. With the regular radials it was doing rolling burnouts at 70mph!!
These stickys fixed that.Had to whip up an air dam. With the hood on it wasn't getting enough flow through the radiator. This dropped my water temps by 20 deg.
Here is the manifold hanging ready to shoot.
i had one made of 1/4 inch abs plastic that was pretty cool. Unfortunately i lost control of the car on the freeway and went through the ditch at about 50 mph, didnt hurt the car at all but the few inches of water shattered the air splitter so ive been kicking around the idea of building my own.
That's my official earth friendly ceramic and powdercoat ventilation system. Pretty high tech huh
Question on the cam. I've read the entire post and havnt seen specs. If you want to keep it quiet I can understand but what was the LSA on that cam? It sounded like a choppy low LSA cam.
By the way, I love where this guy has gone with his build. Beautiful, powerful, and efficient.
