Finally started the twin turbo project!
Old Jun 25, 2010 | 03:20 PM
  #221
Boosted One's Avatar
I think I may add a rear sway bar in it. Your right it does look like it needs one.
Frank
Old Jun 25, 2010 | 07:00 PM
  #222
98Z28CobraKiller's Avatar
Restricted User
Frank
Getting rid of the twist improved my 60' by .2 in the 60'. It's amazing but it makes for a more boring ride when you aren't all twisted up coming out.
Old Jul 7, 2010 | 04:13 PM
  #223
Drewhelm's Avatar
I have to say I love this build. I am doing something very similar with my 69 firebird and using the same turbos with a 6.0L. I noticed in one pic there is a t-fitting where the oil pressure sensor used to be and looks like you are running oil lines from there to the turbos. What kind of fitting is that and did you put the oil pressure sensor somewhere else? Is it required?
Old Jul 8, 2010 | 07:40 AM
  #224
Fireball's Avatar
I saw his new bullet...sure is pretty
Old Jul 8, 2010 | 07:59 AM
  #225
Thank you! The fitting is just an metric adapter fiting from auto meter. Then I used an 1/8" npt to 4an T. I got rid of the factory elec oil pressure sender. It's not required.
Frank
Old Jul 8, 2010 | 08:13 AM
  #226
Thanks again for use of the super tool! Mad life alot easier.
Motor is all together and ready to go in. After some minor oil pan clearancing
Old Jul 8, 2010 | 08:23 AM
  #227
71 chevy's Avatar
here is another idea
http://www.stevesnovasite.com/forums...1&postcount=88
Old Jul 8, 2010 | 08:26 AM
  #228
71 chevy's Avatar
hey, what happened to the other motor?
Old Jul 8, 2010 | 08:51 AM
  #229
helicoil's Avatar
Very nice results, killer leave! Nice street car.
This is such a temptation thread to do the same to my 66.
Old Jul 8, 2010 | 09:28 AM
  #230
It walked all the main caps. Started to chew the main bearing up. Luckily I caught it real soon and cut the filter apart before any real damage occured. It's at the machine shop now getting the crank polished.
I ended up building an iron block 402 with Manley rotating assembly.
Old Jul 8, 2010 | 12:26 PM
  #231
Drewhelm's Avatar
Frank
Perfect, thanks! Do you happen to remember what size metric adapter it was? Obviously it converted it to 1/8 NPT.
Drew
Old Jul 8, 2010 | 01:02 PM
  #232
71 chevy's Avatar
damn. that sucks. any idea why it happened?
Old Jul 8, 2010 | 02:49 PM
  #233
Drew
Autometer part # 2268 M16x1.5 to 1/8"npt.
Old Jul 8, 2010 | 02:53 PM
  #234
the main caps were moving around on the block. It would have been ok if I had arp main studs, but I built that bottom end years back for a heads/cam and small shot of n2o.
Old Jul 8, 2010 | 06:11 PM
  #235
Drewhelm's Avatar
Thanks!!!
Old Jul 9, 2010 | 03:07 PM
  #236
CarsandWomen's Avatar
jesus, takes some doing to walk em around like that. with the new power your gonna have to add some thing to control the twist, that big stroke will torque it all the way out. still a beautiful car, wish i could see it in person, I get the distinct feeling that the pics just dont do it justice
Old Jul 11, 2010 | 06:36 PM
  #237
Thanks. I have actually been looking into rear sway bars. I'm going to get a universal one and put it in this week. I've been wanting to do it for a long time, so this kind of forces my hand.
Come on over to my neck of the woods, you can see it in person and go for a ride!
Old Jul 21, 2010 | 06:12 PM
  #238
gnnova's Avatar
I've seen it in person and it is every bit as nice as it looks in the pictures. He is an excellent craftsman. I just have not got a chance to get over to his place for a ride since he got it running.
Ken
63 Nova HT LS Project
87 Buick GN
Old Jul 21, 2010 | 11:31 PM
  #239
turbo_ase's Avatar
quick question ...well first let me give you your props...beautiful car nice work and nice times at low boost...the question is what type of fan you using...I got a heating problem on my set up...right now..
Old Jul 22, 2010 | 08:04 PM
  #240
Ken
87 Buick GN
Thanks Kenny! Get your *** over here and let go for a rip!
Thanks! Cooling is a little bit of a concern for me also. The car runs at 185* almost alway's, but when it's 95+ out coolant temps can get as high as 205. But they have never really gone above no matter how I run it. I'm running a single 16" spal fan with an aluminum shroud on a universal Norther radiator that I converted to dual pass. Going dual pass and making an air damn for underneath the car seems to have made the biggest difference so far, but I think I'm going to massage 2 12" fans in there over the winter.
