Finally started the twin turbo project!
By the way, I love where this guy has gone with his build. Beautiful, powerful, and efficient.
Will do Mike. You should be getting a few calls from some people I gave your # to down at the OC car show.
how did the track outing go?
Keep up the fab work.
http://www.youtube.com/watch?v=j43jg...eature=channel
Thanks! . It has Mahle forged flat tops, and Eagle H-beams. I noticed a 6-8psi drop in oil pressure so I cut open the filter and found some gold flakes so I'm building a 402 iron block right now. Should be done next week I hope. I'm running 3.54s in the rear.
can you remind me the specs of your cam again, and where does it peak? I might need that cam lol
thats hella good. congratulations
Frank
btw, just saw the vid. NICE.
that street car MOVES. looks like the front suspension is also set up well to transfer weight. can you tell us some more about the front suspension?
The front suspension is a Heidts mustang II tubular setup. I just added Qa1 10 way adjustable coilovers. I set them on 90/10 for the track and it seemed to work well. Only thing that kills it off the line is the fact that the converter is too tight.
Was just thinking about selling the cam, no way I'm selling the car!
