Finally started the twin turbo project!
Old Jul 23, 2010 | 11:50 AM
  #241
71 chevy's Avatar
hey boosted, do you have data on how much each of those turbos flow?
Old Jul 23, 2010 | 08:40 PM
  #242
Boosted One's Avatar
Sorry, I don't have any numbers for them. I looked for compressor maps also and couldn't find them online. I can tell you they worked well on my 346 and they work even better on the 402!
Old Jul 23, 2010 | 11:21 PM
  #243
71 chevy's Avatar
yeah? pretty cool. how many rpms sooner are you seeing boost and max boost with the 402
Old Jul 23, 2010 | 11:26 PM
  #244
hmm, it's hard to tell. My converter was on the tight side with the 346 and with the added torque of the 402 it has loosened up some. By the time the converter flashes it's in boost. I'm very pleased with the combo! When my gopro camera comes in I'll post some video of it.
Frank
Old Jul 24, 2010 | 01:09 AM
  #245
Marktainium's Avatar
Your build has inspired me. Building all forged 402, low compression, Precision hp 6265's w/.82 ar. Using 'vette manifolds. Can you tell me more about clearancing for the 4" stroke.
Old Jul 31, 2010 | 02:13 PM
  #246
Great looking build! As far as crank clearance, I had to put space down the windage tray and cut that hole in my F body oil pan then weld a plate on the outside. Other than that you just have to verify your pickup isn't too close to the bottom of the pan after you space it down.
Frank
Old Jul 31, 2010 | 02:38 PM
  #247
Got to run the car at the track today and had a fairly good outing. I'm having some major traction issues. My best 60ft was 1.57! I had to pedal it through most of 1st gear and short shift into second to get it to do anything. But it's not all bad, I still ended up with my best time to date. It went 9.32 @ 152mph! Needless to say I'm pretty excited about that. Boost was set at 15psi so once I get some more seat time and get the traction issue straight, I'll start turning it up.
Old Jul 31, 2010 | 04:17 PM
  #248
71 chevy's Avatar
good numbers. really good.
is it a manual vb th400? if it is, you could launch in 2nd gear. that would help with the traction
Old Jul 31, 2010 | 09:45 PM
  #249
hmm. that's a good idea! I'm going to try that next time.
Old Jul 31, 2010 | 11:42 PM
  #250
71 chevy's Avatar
no problem. my th400 has an unfriendly 2.75 1st gear, so I ran the combo thru eta for windows and it actually showed the combo going faster launching from second gear.
Old Aug 1, 2010 | 07:43 AM
  #251
Fireball's Avatar
should've gotten the glide
Old Aug 1, 2010 | 07:46 AM
  #252
lol, you told me that when I was building it! I'm a little hard headed huh.
Old Aug 1, 2010 | 09:35 AM
  #253
Fireball's Avatar
turbos and glides go together like peanut butter and jelly
Old Aug 2, 2010 | 05:59 AM
  #254
Fireball's Avatar
we weighed the "heavy chevy" yesterday damn frank...you need to put that thing on a diet
Old Aug 2, 2010 | 06:23 AM
  #255
02sleeperz28's Avatar
Very nice build.
Old Aug 2, 2010 | 06:47 AM
  #256
Car weighed in at 3533lbs. I was expecting 3200#. lol
Here's a vid of the pass.
http://www.youtube.com/watch?v=_7cNy...eature=channel
Old Aug 2, 2010 | 08:49 AM
  #257
TracyRR's Avatar
Wow, you made that look easy!!
Old Aug 2, 2010 | 02:36 PM
  #258
Drewhelm's Avatar
Hory Clap!!! That thing MOVES!!! Can't wait to get mine done....truly inspirational.
Old Aug 3, 2010 | 07:04 AM
  #259
CarsandWomen's Avatar
maybe its just me but i think theres an 8 sec pass coming up, 9.32 at 15 psi with traction problems says its coming too.
Old Aug 3, 2010 | 08:37 AM
  #260
I would be soooo happy to see an 8 sec pass out of it. Not saying I'm not excited about what it did run. I'm certainly suprised! The best part is I was on the rev limiter at 7200 right around the 1000ft marker. So it looks like a gear change is in my future. They might help with the launch too. I would imagine if I took the full exhaust off and put the side dumps back on it may pick up some too.
Thanks for the kind words everyone!
Frank
