Question for Harlan or anyone else experienced w/ the tach wire
I'm going to be installing your shift light, 2 step, and a window switch, what is the best way to tap into the tach wire, will there be any problems w/ 3 such devices pulling from this wire? Thanks.
the 2 step doesn't use the tach wire, so no worries there.
you shouldn't have any problems with 2 things on the wire. It doesn't actually go inside the car, so you'll have to tap it at the PCM, or at the connector on the passenger side inner fender. It goes to the throttle relaxer if you have traction control, other wise it just dead ends at the connector.
