Finally dyno'd my 370/F1 setup
Thanks Ricky, that would be awesome if he could help out!
I was just playing around with WinPEP comparing runs 26 and 28. At 5500RPM, run#26 is almost 30HP higher, and over 25TQ higher than the "best" run. I think that, had traction been available, I probably would have seen 720ish RWHP and 615ish RWTQ.
I know its just bench racing... errr even worse- bench dynoing LMAO But its all I have to show for now. Maybe I can sneak a shakedown pass in at the track before it closes for the season
i don't see 800's out of ?. i was wondering why you went with a 370? it seems like people are liking the extra revs fromt the 370's. were you looking for 7krpm?
im going to go and start from the begining on your threads ive been through them several times in the past and you've helped me with some questions through some pm's and i thank you for that. good luck buddy and expect some pm's in the future i should have have my d1sc similar to ricky's in march
I know I haven't mentioned it, and it kind of goes unappreciated without saying, but this was the first time in a LONG time that I have not had anything break on the dyno! Last time it was the fuel pumps that took a crap on me (got some knock off walbros I think), the time before that, it was a massive coolant leak from the block somewhere , time before that, it was something else stupid and irritating ...I felt so relieved that nothing broke this time and was happy about that probably more than anything else. And it made me especially proud knowing that I built this entire engine myself this time around! Hell, by now, pretty much the whole setup has been built by yours truly, and I couldnt be more satisfied with it all
Best of luck Chad. Its come a long ways and I know you were disappointed the day you dyno'd at Powerhouse when I met you. You'll get it all figured out and I think a SD is gonna be the best route on that beast. Its a great feeling when you've done all the work and even more so when it all stays together!
why dont you put it on some slicks, on the dyno just run them with good air pressure in them. were you dynoing with the air filter on if you were you will find quite a bit of power in pulling that off.
I am well aware that pulling the hat/ filter off typically gains a lot of power. I gained something like 90rwhp with it off on my 346/P1SC combo. The thread is in here somewhere if you want to do a search. I've also posted that graph in many threads here in the FI section. I did pull the hat and filter off on one run this time, but it made virtually no difference. Still ran pig rich, and didn't make any more power than with it on. So either this hat and filter setup is way better than the stock fbody one from procharger, or its still just entirely way too rich at this point for it to matter.. I'm leaning towards the latter, but maybe a bit of both. Hard to tell until somehow the AFR gets in check to begin with first.
