boost controler?
whats a good unit, what features are important? what features are not worth paying for. would one of there units take the place of a boost gauge and free up a little gauge space.
How convoluted is your setup?
How much max boost?
Do you want stuff like gear/rpm/speed dependent boost?
Do you need different 'profiles' for various octane?
That's just off the top of my head, there's probably more. Gimme some detail and I'll get back to you with some choices. or just AIM me at 'bushmannt'.
has a lot of features for a good price, mighty mouse had it for a while or still does maybe he can chime in
Is it dependable?
can you run more boost at higher rpm's, if you can i might try and mess with the boost vs rpm feature. i mainly want something that i can adjust easialy and acurately but some of those other features might be nice some day.
Adjustable check valve (relief valve) part # B-4CPA2-3
Parts are brase 1/4" male npt connections. You can get them in female npt, stainless, etc.
The parts are from www.swagelok.com This is not in-car adjustable but I did not want it to be. I also have a thumb adjustable back pressure regulator (relief valve) that I may try, but have not had time.
Gary
3 boost settings (internally or externally activated)
1 boost dependent output (used this to turn on second fuel pump)
has audible alarm, bar graph and digital readout you can set to whatever scale you want.
fits in a 2-5/8 gauge pod or a/c vent on a firebird.
well heck read this
http://www.turbosmart.com.au/boost_c...electronic.htm
and i got mine on ebay for 450.
