boosted cam?
Old Nov 27, 2009 | 05:56 PM
19trans_am98's Avatar
Default boosted cam?
i have a 220/220 .565/.565 114 laying around would this be enough to push a 347 into the 9's or would i need a little more duration?
Old Nov 27, 2009 | 06:25 PM
old motorhead's Avatar
Good question. Another one might be "how much boost would it take to get a 347 powered ride weighing "X" into the nines with a 220/.565-114lsa cam. Nail down a few variables.
Old Nov 27, 2009 | 06:43 PM
car weighs about 3400 with me in it...gonna run about 14lbs of boost dunno if it will put it there or not...just had the cam laying around....wasnt sure just thought i would get some input
Slowhawk's Avatar
LS1Tech Sponsor
You'll need alot of boost.
Old Nov 27, 2009 | 07:01 PM
somewhere in the 15-20lb range? or just go ahead and get a diff cam?
Old Nov 27, 2009 | 07:42 PM
I don't think a bigger cam will make a huge difference. If you have all the bolt ons, tranny, converter, gears etc, with 15 to 20psi, you can run 9's. You might not make it into the 9's, but I don't think that cam will be holding you back.
Old Nov 27, 2009 | 09:12 PM
6techniques's Avatar
umm...what size turbo?
Old Nov 28, 2009 | 06:59 AM
stock48's Avatar
9 Second Truck Club
I think thats plenty of cam. I went 10.59 @4950lbs 4x4 truck with a little 212/212, .527''/.527'', 114* 6.0L and 10.33 with a 215/215, .566''/.566'', 114* 370CI That was on less than 16Psi of boost with a Tc76, 317 heads. Parish went mid 9's in that farmont with a stock 5.3L with a Z06 cam.
Old Nov 29, 2009 | 04:09 PM
as of now i have a 70mm and it just pushed my lil 4.8 to a 11.1 on 10lbs and was way lean i feel that i could have made it into the tens with a lil more fuel....building my 347 thats why the 4.8 is in there had to have something to drive lol...but i may step up to a 76mm before its all over with
