Smoking from exhaust? ideas?
Old Nov 29, 2009 | 05:09 PM
V8RX7FTW's Avatar
Default Smoking from exhaust? ideas?
I just got finnished doing a turbo build and my motor prior to the build did not smoke and had perfect compression. I'm thing this is a pcv issue possibly due to me getting new valve cover and I did two -8 lines off the vave covers into a catch can. The can itself billows smoke which is something else I have never seen happen. Oil may also be the issue as I used 15w-40 race oil. Things i have checked..the turbo is not leaking oil into the exhaust and it drains just fine. Car still needs tuned a bit but i already changed my injector tables so it shouldn't be too rich as the wideband is reading around 14.2 at idle when warmed up. Any ideas would be of great help and maybe someones had this issue before. Thanks and heres a pic of the setup if that helps
Old Nov 29, 2009 | 05:25 PM
blk00ss's Avatar
puffing from the catch can? Sounds like blow by? But if its new maybe it needs more time to seat the rings better...
Old Nov 29, 2009 | 05:37 PM
V8RX7FTW's Avatar
not new but the same ls6 i was running all motor before never had any issues before and i haven't even driven it hard or started tuning it with the turbo so i dunno. I did read somewhere if you don't baffle the valve cover it can cause the breather to smoke.
Old Nov 29, 2009 | 05:41 PM
V8RX7FTW's Avatar
I guess the fact that the motor was fine before and didn't smoke at all makes me think it has to be ok. Its only been idled and never driven in boost yet.
Old Nov 29, 2009 | 06:33 PM
98Z28CobraKiller's Avatar
Restricted User
Is it a stock LS6 or forged?
I ask because there is a known issue on the C5 Z06's with the rings hanging up. I can't remember the fix now though.
Old Nov 29, 2009 | 07:22 PM
98Camarod's Avatar
It's just smoking out of the catch can? Your PCV system is only the lines going to the catch can and the intake ports are blocked off right?
I'd place an steel wool pad in the top of the can, the one that doesn't have any soap in it that can be found at your local grocery store. I had the same problem and did that and all is well now.
Old Nov 29, 2009 | 07:28 PM
V8RX7FTW's Avatar
Also smokes out of the exhaust and its a stock ls6 for now low miles around 20k and its a 2003 or 04 block
Old Nov 29, 2009 | 08:18 PM
98Camarod's Avatar
When you put the brillow pad under the filter that should stop the smoke from the catch can. You did block off all the other PCV connections correct?
For the smoke out of the exhaust, did you upgrade your springs? Do you have any oil in your intake?
98Camarod's Avatar
Old Nov 29, 2009 | 08:22 PM
V8RX7FTW's Avatar
yea all old ports are blocked. I will have to look in the intake but spings were upgraded a long time ago with new seals. I'm starting to think maybe the drain is the culprit. Its almost parallel with the ground...not ideal by any means but i didn't see any signs of oil leakage in the turbo. I would expect to find oil in the intake and exhaust of the turbo housings correct? drain is -12an btw
Old Nov 29, 2009 | 08:49 PM
98Camarod's Avatar
If it's parallel then I'd say that's the smoking out the exhaust problem right there. So you will either have to tap lower but still above the oil level or get a pump. Then clean up the intake and intercooler if there is any oil in their so it doesn't adversely affect your tuning.
Old Nov 29, 2009 | 09:08 PM
V8RX7FTW's Avatar
What if there are no signs of oil on the intake or exhaust side. Could it still be leaking oil in on the exhaust side and just burning it cause the compressor side was clean as can be and had no oil in it at all.
Old Dec 1, 2009 | 01:34 AM
barnat's Avatar
Default Pull the TB !
I had a simular (**** U ATION )LOL when i did my build and installed my brand new Rossler stage 3 auto tranny LOLThis bitch started smoking! Here ,,its was the vac modulator inside the tranny was leaking and tranny fluid was being sucked threw the vac line and into the intake Not sure if your an auto or not, but figuired it was good info just incase. Pull the TB and see what the intake looks like inside then go from there ?If nothing in the intake ,ide say its the turbo drain setup Definatly!Or hopefully you havent been to a Pittsburgh Steeler game lately with that baby LOL Make sure you aint got a terrible towel stuffed in your exhaust pipe LOL Just messen man ,,I know your a Bengels fan LOL
Old Dec 1, 2009 | 02:03 AM
barnat's Avatar
On another note,,,Just to double check the drain .With your oil level full or at where ever you keep it,,, disconnect your drain hose from the oil pan to see if any oil comes out of the oil pan. If it does ,,,then you found the problem because even with the engine off the turbo oil still has to be able to drain or it will collect in the turbo and seep past the turbo seals causeing your smokeing issue!
Old Dec 2, 2009 | 10:34 PM
blacksi's Avatar
I'd do a compression check on it. You remember the whisping of smoke on mine? Yeah a few month later as the smoke got a little worse=hole in #7.
Old Dec 3, 2009 | 07:15 PM
Boo"SS"t's Avatar
Just wondering. Have you checked the spark plugs for any signs of oil? Is your turbo a brand new unit or used?
Old Dec 3, 2009 | 08:08 PM
1989k1500's Avatar
If your turbo drain is almost parallel to the ground that is going to be a problem.
Old Dec 6, 2009 | 12:29 AM
V8RX7FTW's Avatar
no oil on plugs intake clean... oil drain has oil sitting in it. Gonna do a new oil drain this week. Should fix it. No hole in number seven as of yet. lol
