Water/Alky???????
Old Dec 13, 2003 | 04:56 PM
Blown98's Avatar
Default Water/Alky???????
Im fairly new to the forced induction f-body, but what is the water/alchol for, how does it work, should i look into getting it? thanks
Old Dec 13, 2003 | 05:18 PM
69firebird's Avatar
the
water basically makes the charge cooler, the alky will make it cooler and also add some octane benefits.
saves alot of money on race gas, will allow you to run higher boost with out using race gas
Old Dec 14, 2003 | 12:29 AM
Rob Raymer's Avatar
We use it on our Project Turbo Formula and it works great! You can read up on our results on the website under the Project Car section on the Formula.
We also just added the complete systems to our website for online ordering.
If you have any specific questions, let me know.
Hope that helps.
Old Dec 14, 2003 | 03:53 AM
Blown98's Avatar
Well would it be worth it to put it on my car? How is it injected and where. Is it on all the time or just when you want. Does it add any power just by putting it on? Thanks for all the info
Old Dec 14, 2003 | 03:06 PM
teamsleep13's Avatar
It is worth it if your running close to detonation.
Normally your gonna have a small tank of the the water/alky mix, and pump that will go to a few 'misting' nossles before your TB.
You can rig the pump to a switch or to a pressure switch that will come on when your boost reaches a certain level.
A Supra we worked on was running 15 psi from a single T76. Car made almost 900hp/ft-lbs, but detonation was limiting the cars power on pump gas. After we rigged up a small alky/water system the car's intake temps dropped almost 45 degrees, and we gained 65 hp across the entire rpm band.
If your wanting more power, then go for it, just make sure to keep it filled so you dont think u have it when u run the enigne hard.
Hunter
Old Dec 14, 2003 | 03:09 PM
Nickn20's Avatar
if you are lean and detonating, it will make more power by just adding it, any other situation other than that, the awswer would be no.
you really need to tune around the kit, the alky/water cools intake charge, and you have a higher octane mixture in your cylinders allowing the increase of timing and/or boost, and that is where the power comes from
Old Dec 14, 2003 | 03:24 PM
Blown98's Avatar
ok thanks guys, ill keep it in mind but only when im making lots more power.
Old Dec 14, 2003 | 05:22 PM
69firebird's Avatar
well you can tune around the kit, but when you tune you can add more timing and bring yourself to the brink of detonation and then add the alky and you will be better.
