lb/min vs cfm before and after turbo
1291cfm = 93lb of air at 90deg
but only 71lb of air at 262deg
if a t76 is rated at 91lb of air max where is that measured because if the inlet temp is 90deg the output temp will be ~262deg and that is a way diferent weight of air.
i assume the cfm's are constant thru out the system, if the turbo can put our 90lb of air at the incresed temp then once intercooled it will put out alot more air.
does that make any sence, i am not even sure i understand the question but i am sure i would get alot more power with a really good intercooler.
Lets say the turbo takes in 90lb of air at 90 degrees.
It heats that air to 262 degrees and sends it to the intercooler.
The intercooler cools it back down to 100 degrees.
You should still have the 90 lbs of air you started with.
If I understand it right, when its 262 degrees, its the same amount of air, it just takes up way more space.
Once you get the air past the turbo then the mass air the engine sees cannot be changed.
If you put ice in the intercooler on a 100 degree day and saw 50 degree IAT's going into the TB, you'd still have the same mass air reading, just cooler temps and more detonation resistance.
Its the 50 degree days that your mass air readings will get crazy!
so the only benifit to an intercooler is the reduced IAT. it wont actualy see any more lb's of air?
something here is over my head
You have the exact same amount of air in there, but you'll be amazed at the amount of space that air takes up at freezer temperature.
I've seen drag car setups running 22psi with no intercooler. It would be a flow restriction. They are able to run 116 octane race gas, so 350 degree IAT's don't cause it to detonate.
if it was cooler you would be able to push more air past it at the same presure since it now takes up less space. so it seems to me just adding an intercooler as long as it wasn't too much of a restriction would allow you to flow more lb/minute at the same presure.
is there something wrong with that line of thought, it would explain alot for me.
let me get at the whole point of the discusion, i am buying tht turbo kit and the intercooler is TINY, it is rated by spearco for 500hp, i am going to guess that it will be at best 50% efficient at 15psi on a 409, if i put a huge air to air on there and was able to get the efficency up to 80% would i flow more air or just have a reduced chance of detonation. using the turbo charts at smoke em up leads me to believe it will flow more air.
if i enter 409ci, 90%ve, 6000rpm, 15psi, 170deg. i get 1300cfm and 81lb/min
now if i enter the same but with 103deg i get 1300cfm but 91lb/min
i used another page on that site to calculate the intercooler output temps based on 70deg ambient air and 40%efficency for the 1st one and 80%efficency for the 2nd one.
going off that chart it looks like a monster intercooler could be worth 10lb/minute vs the tiny one that comes with the kit i am looking at. i could be way off on that 40%, wont know that till i try it and it will be while before i have a 409 and all the other stuff to even give this a try.
With no intercooler at 20 psi you might see 15 psi intercooled same amount of air.
That one is probably going to be a serious restriction to flow.
I would like to know at what CFM certain intercoolers start to restrict flow.
Or do they just start to cool less, and not restrict too much??
go here http://www.binaryjungle.com/pdfs/Turbonetics2002.pdf
page 41, and look at the 2-231 at 700cfm there is only .1 psi loss but the cooling is droping off fast.
How many cfm are you looking at for your setup, 700rwhp?
