Vortech vs Procharger, Camshafts, and other FI questions
I agree, go with the D-1SC. It comes with the wider 8 rib belt and the larger 4.5" twin intercoolers instead of the thinner 3.5" intercoolers. You have to be careful though, a D-1SC kit can be ordered as a P-1SC with the head unit upgraded to a D-1SC. You end up with a D-1Sc with the 6 rib belt and the smaller intercoolers. I have seen shops try to sell them this way so the customer thinks he is getting a great deal. Bob
Well doesnt this sound like a nice little Vortech bashing session... If you want self contained get a V2 Vortech head unit its self contained just like the procharger. Since you have a TA you can get a V1 or V7 Vortech kits from RMCR performance like mine and make tons of power just like a procharger and it will fit under the stock hood with no issues. If you go with the Vortech and use the air-to-water after cooler instead of the FMIC you dont have to modify or cut up the car any. Just an idea but im sure with this much opposition your mind is made up...Check out http://www.rmcrperformance.com they sell the vortech upgrade kits.
Actually, my mind is far from made up. The Vortech kits I've seen are much more cost effective, and I don't mind the look of them under the hood. The engine bay of a WS6 is far from something to behold anyways. I was hoping to get a little more feedback on the Vortech kits in this thread. That's the problem...just not as much info out there.
Do you know anything about the V9-G trim units? I know you have to tap the oil pan, but I don't know that it is that big of a deal, really. I was only planning on running 6-8psi anyways, so that kit kind of fits my needs. I'd appreciate any other info I could get on the Vortech stuff...
im currently in the same desicion making process, as of right now, i been planning a procharger all the way, but i dont know if thats just becuase all the people here use them.
I do know that a procharger setup is pretty expensive. lol
I have had a Vortech since 2001. I upgraded from a g trim, to a T-trim, to a YSi and then a cog drive. I can tell you the non-self contained oiling is a non issue. I have never heard of anyone having a problem with it (consider that all turbos are fed engine oil). Also you don't have to do a separate oil change for the blower. At a cruise in it gets lots of attention because the blower is there for all to see vs a Procharger where you have to point out where the blower is. All the upper tubing comes off in 5 minutes (held on with hose clamps).
Down sides: You have to be careful with an air/water intercooler. It can't be hot lapped at the track without cooling the water first. Also you can't really get into a prolonged all out driving situation because again the water will overheat and overwhelm the heat exchnager easily (I have dual thermostatic electric fans on an aftermarket heat exchanger). The G-trim only pumps out 800 CFM and can't compete with a 1450 CFM D1SC.
There are a couple companies that sell upgraded Vortech kits, SpeedInc. and RMCR. I know from RMCR you can get options like a custom high flow aluminum air lid and 4" intake tube + a cog drive (I have them all). I wouldn't mind you going the Procharger route though because I like my car being different than most.
#32
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#35
OK guys, the seller from the auction just offered me a kit for $2600 buy-it-now. This seems like a really good freaking deal, but I just had shoulder surgery yesterday and I'm on some strong meds, so I may be missing something, LOL. Can you guys take a look at this link and give me some thoughts?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
#36
My 2002 Z28 has a Procharger D1SC kit. Since it was last on a dyno (years ago) I have upgraded to the 4.5" intercoolers, larger EPP recommended air filter, and the black anodized Procharger bypass valve. I also just recently upgraded to 8 rib pullies and an 85mm MAF. The car put down 479 RWHP before all of the upgrades to the kit. Now it should be North of 500 to the wheels. We are strapping it to the dyno on Tuesday.
The Procharged car is definitely meaner than my Vortech car, but I like them both a lot. THe D1SC is a bigger head unit and flows a lot more. It has more room to "improve" than my Vortech kit - which I have mostly left alone since install years ago.
Vortech:
![](http://www.fquick.com/images/vehicles/full/21752286285.jpg?1254922974)
Procharger:
![](http://www.fquick.com/images/vehicles/full/20354153927.jpg?1212165765)
Dyno pull, Vortech car:
http://www.fquick.com/videos/viewvideo.php?id=8799
I'm definitely not a "heavy hitter" in the FI community, but I think my input would be helpful for someone just starting out since I haven't progressed much further than that myself.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#37
Thanks very much, that's good info. What do you do for air filtration/induction for the Vortech kit...does the kit come with a filter? I see you're running the SS lid, and I'd probably look at doing something like that as well if the kit doesn't come with anything.
#39
The Spectacle lid is great. IIRC, I gained like 19 RWHP. Did 8 dyno pulls to verfiy. 4 with stock lid (and mine has been sanded smooth on the inside top, making it possibly better than a bone stock OEM lid) and 4 with the Spectacle lid.
Was maxing out the stock MAF, so went to ZO6 MAF and a custom retune.
