Too much lag and only 5psi of boost! Please help!!!
I would say its the combo of the large 3" exhaust leading to the turbo, 1.06 AR, and T6 flange all working against you big time! Simply not enough exhaust velocity to get that turbine moving, thats why when you pulled the vac line to the WG, you're still left with 5psi. If you look at anyone's cross over pipes on a front mounted turbo setup they are 2"-2 1/4" Look at it like blowing air through a straw with your mouth, vs a foot long piece of garden hose. The straw's air stream will for sure have more velocity.
I would recommend doing 2.25-2.5" exhaust from the Y to the turbo first, then get a smaller AR for the hotside on a t4.
My next build will be a 440+ LSX.
I am going to messure the exhaust back pressure first then decide if I can tolorate a smaller AR. I am realy thinking of going to a tangent housing and a turbo valve. I am thinking this is the best thing to do, but I might lower the turbine housing ar a little to if I am not making much back pressure.
What your experienceing sounds similiar to a problem I had many years ago on a 1.8 Miata. GT2540 bb turbo (good for 450rwhp) wouldn't build boost with a .86 exhaust, installed a .68 and it was like I was running a totally different turbo, built boost easily in any gear.
I am going to remove it and see what happens. Even if that fixes the low boost problem I am still going to temparaily install two pressure transducers, one in the cold air piping right at the discharge of the turbo and one somewere in the exhaust piping, not sure were yet. That way I can wire them up to my HP Tuners and record the pressure threw a full run. Once I have that data I will know if I can go to a lower AR housing or if I need to get a tangent housing with the same AR and use one of those turbo valve flanges. The housings should be about the same price but the turbo valve and its controls are not cheap. I would like to take care of this with as little money as possible. I realy like the idea of the turbo valve, it should make the car build boost real fast and it should make it a monster ride even on the street.
So the culprit to this is the turbine housing is sized too large for this setup. So I need to get a smaller turbine housing to correct this problem. I think I am going to get a tangent housing this time just in case I decide to do the turbo valve thing. So with this in mind, what size housing should I get for it?
If you was on the dyno and at 5psi continued to keep reving while surging two things would happen. At some rpm eventually it will clear up. The other is you would be putting a lot of strain on the turbine shaft and the compressor hurting the turbo. Eventually it will blow up. If you spray on the stall and a little bit after the launch that will get you up to the higher rpms faster where it may clear the surge.
I think you are fighting an unknown leak vs anything else. That turbo should spool on your setup. I'm able to spool an 80mm 1.25 a/r 87mm turbine without using the quickspool valve just fine. It's a T4 setup though but I would think they would be similar depending on turbine size. What size is your turbine anyways?
