Too much lag and only 5psi of boost! Please help!!!
As for the waste gate and blow off valve, they are both NEW Turbosmart valves, the 50mm Racegate and the 50mm Raceport. At first I was only building 5psi and the racegate had a 7psi spring in it. I have a 5psi spring and a 10psi spring. I can put all three in for a max of 22psi, or I can mix them up for different psi. I that at first the 7psi spring was opening too soon so I changed it out with the 10psi spring and I tested the cracking, full open and full close with some specialized valve test equipment from work. It now has the 10 psi spring in it and it did not change the boost pressure. The Raceport would come open if I reved the car up to 2500 rpm in neutral and held it there. I ordered a spring kit with it and changed it out and tested it as well. It was opening at 15" HG vacuum and it now opens at 19"hg. I never see 19+" HG unless I close the throttle at high rpms. I know the Raceport and the Racegate is not leaking or opening when my boost pressure stops building. When I pressure tested the air side I brough the pressure up to 13psi (any more and my plug on the turbo would pop off) and I removed the sensing line to the Raceport, and it did not open and was sealing perfectly.
I am going to represure test the entire system and make sure the are no leaks. If I can not find any leaks, I am going to install two to three pressure transducers, one at the turbo air outlet, one at the turbine inlet, and one in the Y pipe, wire them up to my HP Tuner Scanner, and make a pass to record the pressure at all these ponits. That will give me 4 pressure point readings. If I have a high delta P across the cold side or the exhaust side, then I will change the piping. If the pressure is not showing a high delta P there and the Pressure ratio on the turbo is low, and there are no leaks, then I guess I need to change the cam. I would say go to a smaller AR housing but every one else seams to be doing great with the 1.08 turbine housing on the GT-88 rear mounts.
Other then these test and these possibilities I have no other ideas what to do.
Does your waste gate ever open in 2nd gear when it spools? It should be making a noticeable noise if it's vented to atmosphere. Are you able to spool it on the foot brake? When you tested the gate opening pressure where did it crack at? if it cracked open at 10psi on the bench then it will open at a much lower pressure on the car due to the pressure on the face of the valve.
Once you get everything working that 4l60 is probably gonna eat your lunch lol.
The brakes will not hold the car past 13% tps so it really does noy have a chance to spool.
When I tested the gate with the 7 psi spring it craked at 9 psi and with the 10 lbs spring I want to say it cracked at 12 or so.
Once it gets to 5 psi boost it has a larrge leak sound comong frome the car. It could be the gate but the dyno operator said it was coming from the air cleaner. I was in the car so I do not know for a fact it was not the gate, I will try more spring next I think, maybe 15# and see if it comes up some.
Yeh, I have a 4L80E and the segment swap waiting for me to build up with a transbrake for it. I have yet to decide on a stall for it. I need something to help it boosy faster.
I still want to put in bigger valve springs too.
On my first stroker motor that I built, I put the cam in a tooth out becuase I had the slack on the wrong side of the chain. The car made 360 rwhp NA. Once I fixed it, it made 490 rwhp. I had tuned so well that besides the power being down, you couldn't tell that there was anything wrong with the car.
Interesting possibility with a used chain or aftermarket double roller.
I'm presuming you had it a tooth retarded and didn't have ptv contact?
How did you realize the issue besides low power, backfiring, stumble ???
Obviously, if I had degreed the cam when I was installing it, I would have seen the problem but that entire process is a pain in the *** and I wont run an adjustable timing gear anyway so if the cam is off, then it's off.
But I still think you have a big boost leak. You shouldn't need 15 psi spring to hit 10psi.
They should be very close. So build a boost leak tester or maybe put the car on automotive smoke machine. You likely have problems at coupler. Use quality silicone couplers with t bolt clamps and beaded pipes if possible.
Many many turbo car boost problems are result of boost leaks. Its number one problem on dsm forums. This will give you not the right boost and also affect spool .
But don't expect super quick spool up with your combo. On the line use two step to build boost and you might want small shot of spray. Go with would think a 3600 or so stall like yank py 3600 or py3400 these are turbo specific application stalls and work great. Gearing well you get different opinions some guys like the 3.08 or so to help things out. I don't have late spool problems and hate low gears off boost so am happy with my 3.54,they are my lowest choice in the dana anyway.
Once you find you got your 10psi or target boost in third then you can work on spool with timing and fuel and launch with two step and stall and then if you still hate your spool up time to change out turbo,go to smaller inlet housing,...etc.
Not actually sure how much cam will make a difference again a lot of theories out there with reverse split ,nomral split, no split and the lsa argument. My cam seems to work good on my car but yours being rearmount should likely copy what the successful rear mount guys are saying. I guess its possible for it to blow out so much boost you can't get up there to where you want but still betting on boost leak and a big one at that and you said you can hear something.
I would cap the wastegate taking it out of the equation all together, find a nice long hill get the car in 3rd or 4th and roll into the throttle SLOWLY!!! and see if that's your problem.
A easy test before doing anything else would to take your finger along the wastegate part that opens to atmosphere and if it's got carbon you know it's opening or leaking.
Most likely if you have a engine problem you should still build boost past 5psi.
