Too much lag and only 5psi of boost! Please help!!!
Something I have noticed here, I have driven my car to Odessa two different times since I replaced the cam. Odessa is about 100 miles from me and our elevation is close to 3900 feet while Odessa is close to 3200 feet. In Odessa the turbo will build boost to 6.5psi while it will only build 5.5psi here. I am thinking part of the reason I am having issues with limited boost is the elevation. Thats why I am down sizing the turbine housing to a .96AR. I will know more this weekend. If the housing fits correctly I am going to start changing everything out tonight and I plan on being finished Saturday or Sunday. I should know more by then. I hope to have everything done Friday night so I can take the car to Penwell Raceway Saturday and start tuning it. If I make it I will be tuning my car and a friends 98 Camaro with a 6.0L and D1SC.
I think Precision told me this will make my GT-88 like their PT-8847 or PT-4788, something like that. I emailed them and asked them to clearifiy that for me. I will post up what they say.
It still is not making any more boost then before. I did not want to do this but I guess I will have to now. When I get back from the track (I am not taking my car) I will pull the wastegate sensing line off the wastegate (and yes plug the line from the manifold) and give it a try. Yes, I will be watching the boost gauge and if the boost climbs over 10psi I will back out of it. This test will tell me without a dought if the wastegate is opening or not. If it makes boost then, then I will just put my other springs in the gate. If it still does not build any more boost.... well I do not know what to do next.
No point in speculating what to do if it does not build any boost. I will just have to see what happens first. I did not try playing with the springs in the gate because I was trying to fix the lag issue first.
I will report back on Sunday after I have a chance to test the gate.
While we were there I spoke with Turbo383WS6 about what was going on with my boost limiting. I am starting to think the wastegate must be opening up. I have had alot of people tell me a 10 LBS spring in the Turbosmart gate will tend to open at 6psi. I will know tomorrow if that is in fact what is happening. If it is then I am going to get a boost controler for it.
One thing is for sure, after today I have no doubt this thing will be a serious beast once i get all the bugs worked out of it.
