JGS 50mm WG big enough for PT88+low boost?
Old 02-07-2010 | 05:06 PM
smokinHawk's Avatar
Well one thing that would probably help is the way it merges to the waste gate. Looking at my kit it takes a right angle to the wastegate so that's probably why I'm only able to get to 12psi minimum.
Oh and tobreak it in just don't push down the gas petal as hard. It's not like you have a Toyota.
Old 02-07-2010 | 05:17 PM
black98ws6ta's Avatar
Originally Posted by Snyper
So I never got a clear answer..will a JGS 50mm wg get me down to 8psi or so? I just dont want to spend all this money on it and have it not work. After trying today im just not going to be able to fit both waste gates. I have one brand new never used silver tial 38mm wg for sale for anyone looking.
Nobody is going to be able to give you a clear cut answer for your combo. Every set-up differs and placement of them is very important. If you want boost control that low I would be using something more then a single 50mm, more like twin 44's/46's, or a single 60mm.
Old 02-07-2010 | 06:16 PM
98Z28CobraKiller's Avatar
Restricted User
Originally Posted by toretto
IMO the .96 will be the choking point. A 1.10+ would broaden the TQ curve significantly.
The way to confirm this is after you tune it, if the TQ starts to taper off, then the back housing is too small.
This is a great turbo for 364ci.
Originally Posted by smokinHawk
Why would you want to go as low as 4psi on a pt88
I mean the turbo is just starting to get into it's efficency range at 15 psi
I agree, no need to go that low.
For break in of the new engine when its ready. I plan on running 7-15lbs normally.
Again, no need to go that low. You will be able to drive around and even roll into the throttle without getting into ANY boost. It's not a problem and break in only requires a few heat cycles or 300-500 miles depending on which school of thought you subscribe to.
Most likely, no. Depending on your WG placement, you will likely creep to around 10 psi. Should put you around 650 rwhp at "low boost". Very manageable and safe on 93 oct with lowish timing (depending on DCR).
Old 02-07-2010 | 08:37 PM
eviltwin_1987's Avatar
i believe he want to run really low boost so he can do races where he turns left and right, not just going in a straight line.
Old 02-07-2010 | 10:08 PM
Snyper's Avatar
No, I want around 8psi or so to help keep my stock bottom end alive and to break in the new engine. Im not sure exactly how much boost my stock bottom end(317s, 228/228) can take before going boom.
Old 04-13-2010 | 02:45 AM
Snyper's Avatar
I have the twin 38s with .3bar springs and with the BC all the way down the boost creeps to 9psi then settles at 7-7.5 till redline..wonder why it creeps that high with both...
Old 04-13-2010 | 08:25 AM
smokinHawk's Avatar
how do you have the piping merging to the wastegate?
Old 04-13-2010 | 12:25 PM
Snyper's Avatar
Each wastegate directly on each pipe right before the merge.
Old 04-13-2010 | 12:40 PM
smokinHawk's Avatar
its probably because they come out at a 90 from the merge.
if you had more of a Y from them you might get a little lower boost.
Old 04-13-2010 | 04:02 PM
Restricted User
That's good enough. Why are you worried about breaking in a stock motor? Did you buy a brand new stock crate engine?
Old 04-13-2010 | 10:12 PM
Snyper's Avatar
When the new block goes in I want to break it in on low boost.
Old 04-13-2010 | 10:39 PM
  #32
Restricted User
I would break it in with no boost. Just stay off the throttle for 200-400 miles. Try not to idle it alot at first start up and make sure it's running on the lean side. You'll be fine.
Old 04-14-2010 | 12:56 AM
  #33
Snyper's Avatar
Yeah for the first few hundred miles ill just go into small boost like 1-2 psi..just to help seat the rings a little better. Im getting the car dyno'd tomorrow possible on 7psi...I wonder what she will make. What do you guys estimate? 13* timing WOT 7psi...317 heads 228/228@114. Im hoping for 5-550.
