EPP Blower Cam Idle Video *Updated, 701RWHP with dyno graphs*
is photobucket a program you have to buy, i see people using it, just never knew what it is, this computer stuff is way harder than building a car, lol
might look into u tube, never messed with that either-my camera takes vids
thanks
thanks
Sounds to me like you have one pump not working although it's a bit high for just one pump it's quite a bit low for 2. I am running stock lines up front and dyno'd quite a bit more than 650, so I am guessing the F-bodies are different in that regard.
with a 4.00 pulley and no meth, it made 650rwhp on a mustang dyno, fuel pressure would drop to around 40, injectors would hit 138% duty cycle. Im going to try and switch from a brass "T" fitting to the home depot 3 to 1 air compressor fitting. i am on the stock feedline.
#35
The fuel rails and -8 line solved the fueling issue, Doc @ EFI Alchemey finished tuning the car last night. Final numbers with the 3.55 pulley are 701 RWHP and 638RWTQ. We tried one run with the cutout open and lost a few hp and trq.
As for the effects cam swap, pre cam dyno was 515/542. The dyno curve shows some problems with the car, as shown by peak power at roughly 5,000 rpm. Post cam numbers with the same 4.00 pulley were 613/535. I want to be perfectly clear about the numbers, I do not think the cam gave me that much more power. The car was not preforming 100% on the pre cam pull. (Previously, the car did 585rwhp on a different dyno and made peak power at 6500rpm). As for the post cam numbers, there was one pull that put down 650 but I believe the car went lean (fueling problem) so i wouldnt count that pull as valid. I have a couple dyno printoffs that I will scan and post Monday. Thanks to everyone involved with this project!
#40
I'm getting EPP Cam for my turbo build very soon I saw a couple of turbo cars with this cam All of them have great results Oh I also like how the car sounds at the idle with that cam...
02NBMFormula Awesome numbers Congrats man.
any graph or vids??
any graph or vids??
