ATI balancer crank pinning write-up.
we drill in from the end horozontally
with a guide plate after the ballancer is on
you can put as many pins in as you like
and as long as you like
full length of ballancer hub if you want
So who sells that pinning kit? That's how I thought they were always done.
or crossways through the ballancer then in to the crank?
if horizontally pic the side withOUT a key way if you have one so you get a half round in both crank and ballancer for the pin
ok not sure whats going on there is you ballancer in two parts ours are all one piece like the oem one
with mine and the ones we do here the ballancer is pulled on to the crank and pulled up in to position and torqued up as normal ,then the crank bolt is removed and the jig is fitted to the crank snout hard up against the ballancer rotate the jig so the hole misses the key way and tighten up ,then drill the hole
it should be half in the crank and half in the ballancer
have you got a pic
