Cheapest Place for an STS System for an LT1
Edit: You have a Camaro, why not get a KYTP front mount kit. Or an Ebay kit and just put a good turbo and wastegate with it.
Jerry
Or its time to break out the TIG and get creative!
Its easy for me to make alterations in a build, but an end user doesnt have the tools or experience to be able to see the easy solution to a mis aligned pipe, or drain line etc. The other problem is price.....its always bad when a custom says.....whos cheapest..? Really, because engine swaps are not cheap. Engine rebuilds are not cheap either.
When I do a system.......it includes....
a scan guage, injectors, fuel pump, intercooler, water /meth, turbo, pipes, clamps couplers, waist gate, bov (if needed), etc etc.....and I will not do it any other way. If you dont want to change injectors because of cost, no deal. If you dont like the look of the scan gauge......no deal. If you do not want to convert to an SD operating system........no deal.
Most stock engine turbo systems I do, also include head studs, heads sometimes, and a zo6 cam.......and of course substantial tuning. Its more then just getting boost to it, its having control of everything when the boost gets there too.
There is a difference in the 400-500 hp set ups and the 500-800 set ups. An sts lt1 will dyno 425 probably......so is it the cheapest?
if it was me, id go with one of realquicks setups. i like the way jon does the hotside and he is a great knowledgable guy. if he did LS1's id buy one of his setups in a heart beat
i now have an 93 lt1 T/A and looking into options..since i was an ls1 owner i have no idea where to start,i can tell a fmic setup on the lt1 seems a lil involved,i got away with the ebay kit last time and dont wana cut up engine bay this time...motor has 177,000 on the clock so.......lots of stuff to look into ,if an sts kit on a well broke in lt1 is sort of safe..on low boost i'll have some fun with it and plan for stroking and forging later
