Turbine trim ?
Old Dec 18, 2003 | 04:01 PM
MYTURBOT/A's Avatar
Default Turbine trim ?
I`m lookin to order a bigger turbo And need to know what the different Turbine trims mean as far as performance and lag? what one do you think would work best on a stock cube ls1 with a T76 and a 1.13 A/R. I know the A/R is big but top end is more important to me then lag so if it spools decent, like 3500rpm I`ll roll with it. Thanks.
Old Dec 18, 2003 | 05:19 PM
Whistler's Avatar
Sawzall and Welder Mod
1.13 AR will hurt your spool time while giving you no benefit up top, especially with a TT kit.
Use a 76MM .96 AR -Q trim
Old Dec 18, 2003 | 06:22 PM
MYTURBOT/A's Avatar
curious, why do you think that? Everyone i`ve talked to said that the TTi kit could benifit alot from the larger A/R because of the restrictive log. How much more lag would i be looking at.
Old Dec 18, 2003 | 08:08 PM
Whistler's Avatar
.96 is the larger AR. .81 comes on the 60 with the kit, right?
Go ahead and try the 1.13 if you want, but the 76 with a .96 AR is a proven combination. It still will have some lag, but it will be worse with the 1.13
Old Dec 18, 2003 | 08:20 PM
MYTURBOT/A's Avatar
the t60 kit comes with the .96 A/R. Whats the differance between the o, p, and Q trim wheels?
Old Dec 19, 2003 | 06:40 AM
parish8's Avatar
single digit dreamer
i dont know $hit about turbos but when i asked about that 1.13 trim the turbo guy told me that is sized more for like a 400+ci motor at 8000rpm.
told me to stick with a t76, .96ar and qtrim, seems very popular.
Old Dec 19, 2003 | 09:13 AM
ChrisB's Avatar
Friend had a Q-trim with a 1.13 A/R on a 383. It spooled up to 15lbs at around 3000rpm. You would probably be better off to stick with the .96, but go with t-76 GTS. Housing are pretty easy to change (though don't know how access is to the turbo on the kit), and you can pick up a new one for a couple hundred bucks, so you aren't permanently locked into whatever you buy.
Old Dec 19, 2003 | 02:06 PM
eviltwins's Avatar
One thing you have to remember is when you change the exhaust housing A/R on a tang turbo it changes the position of the turbo slightly. The difference between O, P, Q, R, and S-trim turbos is the size of the wheel. Each wheel flows more than the previous, going alphabetically. If you're running a single turbo I would run no less than a .96 A/R q-trim turbo.
Old Dec 20, 2003 | 08:21 PM
JordonMusser's Avatar
do NOT get a q-trim, it is too small. I would go with the PT-S wheel.
