LS2 + T76, how much boost should I run
Old Jan 4, 2010 | 03:21 PM
czwalga00gt's Avatar
Default LS2 + T76, how much boost should I run
I have a T76 with truck manifolds. LS2 ported heads, will be using a z06 cam. I haven't purchased the internals yet, but my CR will probably be around 8.75 or 9.
My wastegate springs are 11.6 psi. I'm assuming this should be completely reasonible for pump gas? Power in the upper 600's/lower 700's? Should I go with more or less boost. Really i'm not trying to squeeze every last bit of HP out of the car but i'd like to hit the 700 mark.
What do you think.
Old Jan 4, 2010 | 05:24 PM
99Z28LS1's Avatar
run as much boost as your tuner says it can until it becomes un-safe for the motor, then back it down a little
Old Jan 4, 2010 | 09:22 PM
jason02Z's Avatar
with that turbo ls6 cam and comp. that low you'll prob need at least 15psi. the cam will be the first to hold you back i think too, but a few guys here have made some good power with it. try a search
Old Jan 4, 2010 | 09:54 PM
ModularTurbo's Avatar
Which 76 do you have?
Old Jan 5, 2010 | 01:18 AM
Mas280's Avatar
What do you think.
What kit are you using? I am using a tc78 on my RX7, I should have some dyno# later this month.
Old Jan 5, 2010 | 05:54 AM
venom ws7's Avatar
So its a stock internals now?? I say 11psi is enough for pump gas use...
But maybe you should get a custom cam for the setup I'm sure it will get another 15-25rwhp over LS6...
Old Jan 5, 2010 | 07:06 AM
Turbonetics T76.
No kit, building my own, I pretty much did the hot parts for $1700 less than hinsons kit, probably doesnt flow as well due to the truck manifolds, but the cost benefit ratio wasn't worth it to me. Guys have made 1000+ with the truck manifolds.
Old Jan 5, 2010 | 07:11 AM
Well its stock rods/pistons right now, i have springs/pushrods/cam, which really doesnt matter, but i'm not going to run the turbo setup without forged internals.
Maybe i'll look into a custom cam. I've searched but most of the info is for LS1's or custom builds.
By Brett Foote | 2026-06-04 05:00:17
