370ci, rear mount - suggestions?
Old Jan 7, 2010 | 07:44 AM
  #41
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by The Fugitive
okay so for a rear mount which of these turbos would out perform and out spool (can you put them in order by best to worst in each category) GTMT78 TC78, GTK1000, and T78?
Fastest spooling....TC78, GTK1000, T78, GTM78 and ST80
Most power, ST80, GTM78, T78, TC78 and GTK would be virtually a dead heat.
Old Jan 7, 2010 | 08:00 AM
  #42
sujomatt's Avatar
DrTurbo = The man
I have never heard of the F1 trim before. Is that something proprietary to Turbonetics? Or am I really that much of a noob? lol
Determining BB vs F1 when I buy
Old Jan 7, 2010 | 08:12 AM
  #43
DrTurbo's Avatar
LS1TECH Sponsor
F1 is the turbine trim.
BB stands for Ball bearing.....two different things. You can have a F-1 turbine with Ball bearing...
Old Jan 7, 2010 | 08:18 AM
  #44
sujomatt's Avatar
Sorry I figured BB was Ball Bearing lol - was just trying to figure why there was such a difference in price point **
I get it now though haha
Old Jan 7, 2010 | 10:53 AM
  #45
sujomatt's Avatar
Would my FAST 78mm intake manifold be sufficient? Or step up to the 92? Since you guys recommended stepping up from the 3" outlet of the intercooler to 4" - that would definitely match a lot better. I am worried I'd reach the limitation of the 3" piping - anyone run into that?
Old Jan 7, 2010 | 11:57 AM
  #46
OUTLAWZ RACING's Avatar
Oh no I run 3 inch intercooler piping, the only differance is mine goes to a 4.5 inch elbow to a 90mm t body in wich im changing. You would see a pressure drop over the 78 but should make more power with less boost because of the less restriction. I think a trade off is lower intake temps and less strain on parts, Is it worth it? Its all up to the builder. Imho I would maximize flow to the motor from the turbo and exhaust.
Old Jan 7, 2010 | 12:13 PM
  #47
sujomatt's Avatar
What are you going to be changing? Just curious if a part or 2 might come out of that for sale
Old Jan 7, 2010 | 04:25 PM
  #48
The Fugitive's Avatar
Thanks for the info I guess i will be getting a TC78
Old Jan 7, 2010 | 05:30 PM
  #49
sujomatt's Avatar
Yea i finally saw a pick of the ST80 - that thing is fn HUGE! lol no wonder its at the end of the list for lag.
Old Jan 7, 2010 | 09:11 PM
  #50
HerbCunliffe's Avatar
There is some really good questions and info in this thread. I check the FI section often as to learn as much as I can about turbos and rear mount set ups. Keep at it so I can learn more. Thanks
Old Jan 7, 2010 | 09:14 PM
  #51
180ls1's Avatar
pm the guy jd_z28 he had a setup very similar to what you want with a 6 speed and a 76mm rearmount. See what he has to say.
Old Jan 7, 2010 | 09:27 PM
  #52
sujomatt's Avatar
My check list keeps gettin bigger of what I am going to get... gonna be living outta the damn car when im done lol
Old Jan 8, 2010 | 02:29 PM
  #53
sujomatt's Avatar
I am going to probably grab a Tubular K Member as well from BMR.. Think it will give me better clearance to run a bigger charge pipe to the front of the car (STS stock piping I believe is 2.5" and I think I'll do 3"). The way the piping is going to go to the front I will probably need a driver side SFC now too lol.
